Dave_ciw 507 Posted November 4, 2010 Report Share Posted November 4, 2010 While heading between yards this morning in my VR I stopped at a junction and the Hi speed fans kicked in engine temp soared and a sh*t load of steam from under the hood. I turned heaters on full and limped the the yard. I suspect Thermostat stuck shut so I am about to order a neuspeed unit does anyone have any experience of these and also has anyone any other ideas welcomed.Cheers Link to post Share on other sites
Ian_rogers 0 Posted November 4, 2010 Report Share Posted November 4, 2010 Don't get a low temp thermostat, use standard 80 degree one Link to post Share on other sites
Dave_ciw 507 Posted November 4, 2010 Author Report Share Posted November 4, 2010 No worries have you had experience of the low temp unit? Link to post Share on other sites
Ian_rogers 0 Posted November 4, 2010 Report Share Posted November 4, 2010 No first hand experience but has seen a write up about them n their pretty useless n unhealthyHere's the linkhttp://the-corrado.net/forum/viewtopic.php?f=1&t=68720 Link to post Share on other sites
Dave_ciw 507 Posted November 4, 2010 Author Report Share Posted November 4, 2010 Cheers for that quality read mate will do thermostat and all three sensors now flush the system and fill up with G12+Thanks Link to post Share on other sites
FrostyCab 0 Posted November 4, 2010 Report Share Posted November 4, 2010 I'd change the thermostat housing as well if your doing all that as its failed on both VR I've had! one ended with a warped head and my current one was bodged with instant gasket to seal the cracks!! Ebay is a good source.As previous stated, don't go the low twmp thermostat route as it won't allow your vr to warm up to its correct running temp and engage the warm map and svae you fuel. They do a lower temp rad switch though which isn't such a bad idea for when your stuck in traffic. Link to post Share on other sites
Ian_rogers 0 Posted November 4, 2010 Report Share Posted November 4, 2010 No problem mateThink an admin should make that info a sticky somewhere :-) Link to post Share on other sites
Dave_ciw 507 Posted November 4, 2010 Author Report Share Posted November 4, 2010 I'd change the thermostat housing as well if your doing all that as its failed on both VR I've had! one ended with a warped head and my current one was bodged with instant gasket to seal the cracks!! Ebay is a good source.As previous stated' date=' don't go the low twmp thermostat route as it won't allow your vr to warm up to its correct running temp and engage the warm map and svae you fuel. They do a lower temp rad switch though which isn't such a bad idea for when your stuck in traffic.[/quote']am a partner in Golf 1st and have plenty of parts suppliers to hand I just wanted some ideas on the low temp thermo's I have decided to pop her off the road now as the chains are a bit noisy sounds like the top rail has gone completely. Was talking with Tony about changing them but he is too busy until after the new year so one of my mechanics will have to be trusted to do the lot. I have only had it 2 weeks and already she is going off the road ;(I agree totally with popping that info up as a sticky as there is plenty of part numbers and info there very very useful Link to post Share on other sites
FrostyCab 0 Posted November 5, 2010 Report Share Posted November 5, 2010 I know that feeling D@VeR6! Had the new VR6 golf less then a month and the list of repairs goes on and on!I swear, If someone tells me one more time that "wouldn't it be nice if everything in life was as reliable as a VW" I'll punch them right in the stomach! Link to post Share on other sites
