p0u1 14 Posted November 16, 2010 Report Share Posted November 16, 2010 hi peopleas some of you might know iv had running isues for some time now, iv changed evrything that could keep my car from losing its powwer in the higher revs, but still not working right.i bought new ht leads and plugs on the weekend that passed and im still having problems above 3k revs, the plugs i bought this weekend are ngk twin spark plugs they were not the right plugs for the car but very close, there abit hotter, i still think that im posible having problems because there the wrong gap, so dose anyone know what i should gap them too? Link to post Share on other sites
VR6Nat 9 Posted November 16, 2010 Report Share Posted November 16, 2010 It should be 0.7 Link to post Share on other sites
VR6Nat 9 Posted November 16, 2010 Report Share Posted November 16, 2010 here you go... Link to post Share on other sites
p0u1 14 Posted November 16, 2010 Author Report Share Posted November 16, 2010 so 0.0028 inch thanks nat, hopefully i can make my car run like a 2.8 and not a 1.3 lol Link to post Share on other sites
VR6Nat 9 Posted November 16, 2010 Report Share Posted November 16, 2010 no its 0.028 inch. Hope that sorts it for you! Link to post Share on other sites
p0u1 14 Posted November 16, 2010 Author Report Share Posted November 16, 2010 my bad lol, same a vr6 that dont like to rev over 3k rpm and still likes to drink like a vr6 is upsetting lol, thanks Link to post Share on other sites
p0u1 14 Posted November 16, 2010 Author Report Share Posted November 16, 2010 well just had a quick look at the old plugs which were running a bit worse than the new ones and they were at 0.038 inch. Link to post Share on other sites
Lukey. 381 Posted November 16, 2010 Report Share Posted November 16, 2010 bentley manual says OBD1 should be 0.7 OBD2 should be 0.8 Link to post Share on other sites
VR6Nat 9 Posted November 16, 2010 Report Share Posted November 16, 2010 that was the haynes tech data that i got that from... doesnt mention OBD1/2 differences Link to post Share on other sites
rosserooni 0 Posted November 16, 2010 Report Share Posted November 16, 2010 If the plug gap doesnt cure it try changing the coilpack for a known working one.My misfiring problems were down to the leads or the coilpack everytime. Link to post Share on other sites
andyfloss 0 Posted November 17, 2010 Report Share Posted November 17, 2010 although it could be the problem iv not heard of pkug gaps making THAT much noticable difference maybe only slight.... i was told 0.7 anyways and mines obd2 Link to post Share on other sites
p0u1 14 Posted November 17, 2010 Author Report Share Posted November 17, 2010 well i woke up at 7 today and regaped all my plugs and still no cure :-/, i dont even know if its a missfire as theres no bangs or pops, and its to high in the rev rang to feel the engine go unsmooth, alow since changing my plugs my problem of losing power has gone up 1000rpm and is not as frequent im suspecting it is a missfire Link to post Share on other sites
p0u1 14 Posted November 17, 2010 Author Report Share Posted November 17, 2010 would hoter plugs need a smaller gap? as i have sligtly hoter plugs, all my plugs are at 0.028 inch Link to post Share on other sites
VR6Nat 9 Posted November 17, 2010 Report Share Posted November 17, 2010 What else have you tried?? im not so sure the plugs are the problem now... Have you thought about replacing the fuel filter or maybe fuel pump incase its got some cack in it?I guess youve done the obvious, leads, maf, coilpack etc?Best bet at this stage would be to get it on vag com or you may be chasing your tail forever... at least that will point you to the problem. Link to post Share on other sites
p0u1 14 Posted November 17, 2010 Author Report Share Posted November 17, 2010 ok the list of parts: new leads, coil pack, spark plugs, lamba sensor, maf, fuel filter, cam sensor and crank sensore, my car wont talk to vagcom so its a bit of swap this it might work, i was thinking maybe the fuel pump might be giving me problems, i have a golf gti for spares i will have a go at swapping the pump tonight, the only way i can describe it is i floor it in what ever gear, its fine up to 3-4k revs then loses power, i can hold it all the way to redline just a bit guttless, then if i go up a gear, making the revs drop below 3k rpm the power is gone for about half a secound then comes back all the way to 3-4k rpm again Link to post Share on other sites
craggsy 91 Posted November 17, 2010 Report Share Posted November 17, 2010 Have you tried disconnecting battery for half hour to reset ECU Link to post Share on other sites
p0u1 14 Posted November 17, 2010 Author Report Share Posted November 17, 2010 yes try that too, still no good, i just got to be thankfull im almost coming to the end of the parts that could cause the problems Link to post Share on other sites
VR6Wherry 0 Posted November 17, 2010 Report Share Posted November 17, 2010 Have tried cleaning the throttle body, that's what happened on my GTi after a good clean it seemed to solve the issue. Link to post Share on other sites
Lukey. 381 Posted November 17, 2010 Report Share Posted November 17, 2010 is your air filter, intake pipe or cat blocked up thus restricting flow Link to post Share on other sites
p0u1 14 Posted November 17, 2010 Author Report Share Posted November 17, 2010 oh yea i changed the cat and air fillter too, so nothin should be blocked, and i cleaned the tb when i started getting problems and it had no change Link to post Share on other sites
yakuza racer 16 Posted November 17, 2010 Report Share Posted November 17, 2010 check that the intake pipe has no cracks in it, this robs you of power, it was my problem...... Link to post Share on other sites
p0u1 14 Posted November 17, 2010 Author Report Share Posted November 17, 2010 its robbing like half of my engine power or more, but yes i will have a look latter as well Link to post Share on other sites
p0u1 14 Posted November 20, 2010 Author Report Share Posted November 20, 2010 well i changed the pump today, not to hard but you skink of petrol for the rest of the day. but still its not fixed, i might try regaping the plugs a bit smaller see if that helps Link to post Share on other sites
p0u1 14 Posted November 22, 2010 Author Report Share Posted November 22, 2010 ok i checked the intake, theres no problems there, the coil pack has noo cracks in it, theres new ht leads and plugs, the maf, lamba, cat, fuel fillter, cam sensore and grounds have all being changed, im lost now i still have the problem of losing power at about 3,6k rpm its winding me up a fair bit now, has anyone got any idears of where next to look :-s Link to post Share on other sites
Lukey. 381 Posted November 22, 2010 Report Share Posted November 22, 2010 if youre running out of places to look might be worth having a specialist look at it mate Link to post Share on other sites
