andynick69 0 Posted November 17, 2010 Report Share Posted November 17, 2010 hi,need to send my ecu to c2 motorsports for a remap,how easy is this to remove?? Link to post Share on other sites
VR6Pete 1,455 Posted November 17, 2010 Report Share Posted November 17, 2010 5 min job. Under your scuttle panel drivers side. Coule of bolts holding it down and the plug that secures the loom to the ECU Link to post Share on other sites
andynick69 0 Posted November 17, 2010 Author Report Share Posted November 17, 2010 ta pete.may do it tonights as same time as pollen filter Link to post Share on other sites
dman78 1 Posted November 17, 2010 Report Share Posted November 17, 2010 did mine on monday,its on the pass side/middle,be careful when your undoing the wires from the ecu Link to post Share on other sites
andynick69 0 Posted November 17, 2010 Author Report Share Posted November 17, 2010 hang on,one of you is saying drivers side and another passenger?? confused.com?? Link to post Share on other sites
dman78 1 Posted November 17, 2010 Report Share Posted November 17, 2010 you only need to take off the pass side scuttle to get to it,its next to the pollen filter so to me it pass side,either way its like pete said,5 min job Link to post Share on other sites
VR6Pete 1,455 Posted November 17, 2010 Report Share Posted November 17, 2010 Actually on mk3 it is next to the pollen filter wiper mechanism is drivers side Link to post Share on other sites
andynick69 0 Posted November 17, 2010 Author Report Share Posted November 17, 2010 cheers Link to post Share on other sites
andynick69 0 Posted November 18, 2010 Author Report Share Posted November 18, 2010 do i need to disconnect battery for ecu removal?? Link to post Share on other sites
dman78 1 Posted November 18, 2010 Report Share Posted November 18, 2010 i would/did Link to post Share on other sites
VR6Pete 1,455 Posted November 18, 2010 Report Share Posted November 18, 2010 yes, I would just to be safe Link to post Share on other sites
andynick69 0 Posted November 20, 2010 Author Report Share Posted November 20, 2010 ecu disconnected from bulkhead,how do i disconnect the plug,lol???? Link to post Share on other sites
thegoth 5 Posted November 20, 2010 Report Share Posted November 20, 2010 IIRC: At one end of the plug should be a t shaped piece, pull this to release the lock mechanism. Might need a bit of ummph if it hasn't been off in a while. Link to post Share on other sites
andynick69 0 Posted November 20, 2010 Author Report Share Posted November 20, 2010 thats on top? got that off,its the main wiring harness to the end of ecu im struggling with? Link to post Share on other sites
thegoth 5 Posted November 20, 2010 Report Share Posted November 20, 2010 the wiring plug is what I mean. Think it's the end of the plug where the wires go in ( just to make access that little bit harder) . When it's still on the ECU will probably just look like a couple of lugs. about 5mm high and right next to the ecu Link to post Share on other sites
