Crossmember bushes where to buy??
The car is making some serious squeaking noises and Im sure its the subframe bushes as they are the only part that hasnt been changed!
Does anybody know what the part number is and where I can get some?
Ive seen some on ebay but am not sure if they are the same for all Mk3s..
Any ideas?
Thanks
front cross member bushes are according to both of these sellers C & R enterprises only sell VW stuff so they should know have you changed your top mounts front crossmember bushes dont normally make noises as they have the engine weight pushing down on them but can obviously age
Hi I bet you its the stupid to rubber things on the top of the susp at front mine squeeks as well as they don't seat correctly plus VR6s hate road humps ! All Vws Iv'e had do this annoying thing. It must be the way the top rubber mount seat. The ony way I stopped it was to vaseline the the sods or none oil white grease. Hope this helps. I think its where the steering twists very slightly and rubs on the internal cone thingy.
