I asked Designa Dubs this question, and they said there was a big difference (but its only 8mm!?)
If i was going to change the brakes id probably go for the 312mm(or 318mm or something) setup from a seat. Im told these can be fitted easily.
Does anyone know where I can find a definitive guide to fitting the VW/Audi 312mm setup?
or know what parts I need to do the conversion?
i think....
calipers (tho you can use 288 calipers), carriers, some spacers made up, flexi hoses (may be same as 288mm ones tho), pads, discs.
  • 2 months later...
Guest Seraph
What cars came with 312mm brakes? So i can get some parts!
Audi TT, s3, golfmk4 4motion & V5, among others!
If its anything like the mk4's 288s, you just need to replace the carriers and the discs.
I was told that no spacers are required to fit 312s on a VR6 - you just use the standard caliper carriers from a car with the 312mm setup (Audi TT, S3, Seat Leon Cupra R etc). Apparently, these will bolt straight to the VR6 hubs.
Can anyone confirm or deny this?
  • 1 month later...
