did alot of work on my car lately afterwards i found leak near power steering pump, sorted leak by tightening a nut, like an idiot didnt top up and have got slight whining from pump under heavy load checked level and its only just on min, want to drain old fluid and fill with new, how much to fill it do i need to buy thanks guys
If you have a look at the oil and its brown it wants replacing, if its still green its ok, if it is low only use vws own green power steering fluid, its not expensive like £7 from dealers and that will do a full replacement, should be vw part either g002 000 or g004 000 doesnt matter which as they are exactly the same fluid 4 is just the new name for it
