VR6-DUB 3 Posted December 3, 2010 Report Share Posted December 3, 2010 I recently had my vr6 vag com, and these are the results anyone care to share there knowledge regarding them. Thank you.VCDS-Lite Version: Release 1.0Friday, 03 December 2010, 18:39:54.Control Module Part Number: 021 906 256 Component and/or Version: MOTRONIC M3.8.1 HS V04 Software Coding: 00000 Work Shop Code: WSC 013172 Faults Found:01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80) 37-10 - Faulty - Intermittent4 Faults Found:00285 - ABS Wheel Speed Sensor; Front Right (G45) 35-10 - - - Intermittent01276 - ABS Hydraulic Pump (V64) 16-10 - Signal Outside Specifications - Intermittent00290 - ABS Wheel Speed Sensor; Rear Left (G46) 04-10 - Mechanical Malfunction - Intermittent00287 - ABS Wheel Speed Sensor; Rear Right (G44) 04-10 - Mechanical Malfunction - Intermittent Link to post Share on other sites
iceviolet 1 Posted December 4, 2010 Report Share Posted December 4, 2010 Have you been on a rolling road recently?? The last two faults come up after that,just clear them and see what comes back. Front abs sensors are cheap and very easy to fit.Unsure on the abs pump fault though, it may be related to the other faults? Link to post Share on other sites
VR6-DUB 3 Posted December 5, 2010 Author Report Share Posted December 5, 2010 Nope never been on rolling road, will love to go on one though lol, thanx for your imput mate. Cheers. Link to post Share on other sites
bungy 2 Posted December 5, 2010 Report Share Posted December 5, 2010 Try clearing the faults first and then check to see what reappears. Link to post Share on other sites
b road blaster 0 Posted December 5, 2010 Report Share Posted December 5, 2010 as above Link to post Share on other sites
VR6-DUB 3 Posted December 16, 2010 Author Report Share Posted December 16, 2010 Will do waiting for my mate to re vag-com it. Link to post Share on other sites
Lukey. 381 Posted December 16, 2010 Report Share Posted December 16, 2010 the N80 one isnt anything to worry about particularly, did you remove the charcoal cannister from behind the front bumper on offside?As said with others clear first then drive around for a good few days to give it chance to re throw the codes up and see whats reappeared Link to post Share on other sites
VR6-DUB 3 Posted December 16, 2010 Author Report Share Posted December 16, 2010 the N80 one isnt anything to worry about particularly, did you remove the charcoal cannister from behind the front bumper on offside?I will have to speak to my mechanic mate regarding the above because he did some work recently for me. Link to post Share on other sites
