VIW28 29 Posted June 24, 2012 Report Share Posted June 24, 2012 Nice work! Link to post Share on other sites
j4mo 0 Posted June 28, 2012 Report Share Posted June 28, 2012 top work man looking good Link to post Share on other sites
bungy 2 Posted July 9, 2012 Author Report Share Posted July 9, 2012 It's going slow but it is getting there. Link to post Share on other sites
legvw 0 Posted July 9, 2012 Report Share Posted July 9, 2012 Looks good mate, keep going! Link to post Share on other sites
bungy 2 Posted July 11, 2012 Author Report Share Posted July 11, 2012 What are people's views on turbo oil supply and return lines? -3an for supply and -10an for return?What about restricting oil flow/pressure to save turbo oil seals, reduced from main engine oil pressure? Link to post Share on other sites
legvw 0 Posted July 11, 2012 Report Share Posted July 11, 2012 No need to restrict the supply unless your going to run a ball bearing turbo, have the oil return as big as you can make it- I think mine is 20mm I.d. Not sure what that equates to! Link to post Share on other sites
AJmk2 2 Posted July 16, 2012 Report Share Posted July 16, 2012 On my 12v I had lots of oil pressure problems from the supply, pretty sure you can get the feed onto the turbo which has the correct restrictor size built in. That was on a journal setup. Link to post Share on other sites
bungy 2 Posted July 25, 2012 Author Report Share Posted July 25, 2012 I went for black textured and there is a possible group buy if enough interest. I'll post a separate thread to see. Link to post Share on other sites
VIW28 29 Posted July 25, 2012 Report Share Posted July 25, 2012 I did the oil lines for mine yesterday Bungy. I went with 1/4" bsp unrestricted feed and a 16.5mm ID return which I was able to get from a tractor in work believe it or not lol, correct flange and all on it Link to post Share on other sites
spadam 7 Posted July 25, 2012 Report Share Posted July 25, 2012 Group buy would be good i have a few bits in mind. All depends if theres enough intrest Link to post Share on other sites
bungy 2 Posted July 25, 2012 Author Report Share Posted July 25, 2012 I did the oil lines for mine yesterday Bungy. I went with 1/4" bsp unrestricted feed and a 16.5mm ID return which I was able to get from a tractor in work believe it or not lol' date=' correct flange and all on it [/quote']16mm ID sounds big but I'm guessing you are trying to get as unrestricted drain as possible. Did you mount the drain flange high up on the sump? Link to post Share on other sites
VIW28 29 Posted July 26, 2012 Report Share Posted July 26, 2012 Haven't just done that yet as I want to see where the driveshafts sit and in my case they need shortened on one side and lengthened on the other bit yes, it will be as high as I can get it to make sure it has every cance to get away from the turbo Link to post Share on other sites
bungy 2 Posted August 7, 2012 Author Report Share Posted August 7, 2012 It's been slow going but I managed some more on my turbo manifold today. The wastegate flange is positioned and tacked in place. For the transition to the turbo I had to make some custom box section and there is still loads of work to scribe it to size and then the final fit to position the turbo as it is tight for space. Link to post Share on other sites
spadam 7 Posted August 7, 2012 Report Share Posted August 7, 2012 Nice looks like a work of art. What size turbo you going to be using Link to post Share on other sites
bungy 2 Posted August 7, 2012 Author Report Share Posted August 7, 2012 What size turbo you going to be usingI'll let you know when I see the results. Link to post Share on other sites
bungy 2 Posted August 8, 2012 Author Report Share Posted August 8, 2012 2 steps forward and one step backWastegate flange needs rotating and the trial fit today showed just how tight for space it is. Should be able to keep all the oem heat shields though. Link to post Share on other sites
spadam 7 Posted August 8, 2012 Report Share Posted August 8, 2012 You going to use a 38mm wastegate? Link to post Share on other sites
cabrioman 6 Posted August 8, 2012 Report Share Posted August 8, 2012 likey like ..... Link to post Share on other sites
bungy 2 Posted August 8, 2012 Author Report Share Posted August 8, 2012 You going to use a 38mm wastegate?I already have the wastegate and it is 38mm. A bit of a compromise for it's position so I hope it will work well. Link to post Share on other sites
jims13 6 Posted August 8, 2012 Report Share Posted August 8, 2012 nice Link to post Share on other sites
michael5556 247 Posted August 8, 2012 Report Share Posted August 8, 2012 Very nice. Link to post Share on other sites
legvw 0 Posted August 8, 2012 Report Share Posted August 8, 2012 Top work mate. Link to post Share on other sites
VIW28 29 Posted August 8, 2012 Report Share Posted August 8, 2012 Excellent! These old 24v turbos are going to be common as muck soon! Link to post Share on other sites
cabrioman 6 Posted August 8, 2012 Report Share Posted August 8, 2012 just give more races 12v turbo v 24v turbo lol Link to post Share on other sites
craggsy 91 Posted August 10, 2012 Report Share Posted August 10, 2012 No one wants 24v turbo cars. There shit!Oh hang on Link to post Share on other sites
