chufferman 0 Posted February 3, 2005 Report Share Posted February 3, 2005 got a bit of a strange one. started missfiring a few weeks ago so i ordered some new silicone leads fit them and its still the same but when you floor the thing it flys but it wont drive round town!?? !amazed x) ?! ?! Link to post Share on other sites
acf8181 0 Posted February 3, 2005 Report Share Posted February 3, 2005 are the leads deffo on properly? when were your spark plugs replaced last? try spraying water lightly over the coilpack at night and see if theres any sparks (try this on the leads as well). Link to post Share on other sites
chufferman 0 Posted February 4, 2005 Author Report Share Posted February 4, 2005 the plugs r new and the leads r silicone brand new as well. I have been thinking it could be the coil pack. Link to post Share on other sites
acf8181 0 Posted February 4, 2005 Report Share Posted February 4, 2005 just re-read your first post....it was misfiring on the old leads as well? if so, that eliminates it being leads (or means its quite unlikely....both sets could be dodgy (i have known someone buy new fancy leads and one be defective) but it would be a one in a million thing)next thing i'd do is get the fault codes checked.could be coilpack (this would not throw up a fault code), but it could also be a number of other things. coilpack is an expensive thing to replace on a whim.a lot of people reckon its really common for coilpacks to fail, but from my reseacrh i've found very very few cases of it....one perosn on here has had one let go and thats it i think. it is common on seat cupra's with 1.8t engines...i wonder if this is why people think its common on vr6's.hall sender is more common prob (this would throw up a code) and could possibly give the symptoms you're describing. Link to post Share on other sites
chufferman 0 Posted February 6, 2005 Author Report Share Posted February 6, 2005 cheers for the pointers mate. havin to bite the bullet and book it in at vw and ask them to find the fault can't afford to keep throwin money at the dam thing. this thing is really doin my head. Link to post Share on other sites
acf8181 0 Posted February 6, 2005 Report Share Posted February 6, 2005 just get them to check the fault codes whilst you wait....they'll charge you £35 prob, but make sure what they do is delete all the fault codes, then take it for a drive (and make sure it misfires), then check them again (with engine running or it throws upa code). Link to post Share on other sites
Switch3sixty 0 Posted February 7, 2005 Report Share Posted February 7, 2005 I've kinda got the same problem but mine doesnt fly drove fine on my way out and was ok most of the way back from a 60 mile trip, about 5 miles from home it lost power, would still go but feels like she's running on 3 instead of 6 Cyclinders? had a quick look under the bonnet but was too busy to have a proper play, started her again but still the same. I've got 4 days off starting tomorrow so i'm hoping to get to the bottom of it. Plugs, Leads then....? Link to post Share on other sites
chufferman 0 Posted February 7, 2005 Author Report Share Posted February 7, 2005 mines gone like yours now mate. sounds like one of them subaru things. now with no power :-( booked in for wednesday when i finish work. will let u no what they find wrong with the dam thing. Link to post Share on other sites
acf8181 0 Posted February 7, 2005 Report Share Posted February 7, 2005 I've kinda got the same problem but mine doesnt fly drove fine on my way out and was ok most of the way back from a 60 mile trip' date=' about 5 miles from home it lost power, would still go but feels like she's running on 3 instead of 6 Cyclinders? had a quick look under the bonnet but was too busy to have a proper play, started her again but still the same. I've got 4 days off starting tomorrow so i'm hoping to get to the bottom of it. Plugs, Leads then....? [/quote']does it sound rough when idling? if not then it sounds like when my hall sender failed. Link to post Share on other sites
Pete.sVR6 0 Posted February 7, 2005 Report Share Posted February 7, 2005 Have just read this post, and I can tell you that, I had to put my car in to AMD the other day, for similar problems, a couple of times it had developed a missfire usually from cold but more importantly it had felt like it had lost power. IT was put on diagnostics and I was told that they couldn't really find a cause for the missfire although the plugs were well passed their best, but also that they were getting a G40 sender/sensor? fault. This was replaced, fault dissapeared and in the words of the technician, it now feels like a different car. As ACF8181, has said, best to get it on diagnostics, it is the best way to tackle these sort of problems, as you could spend alot more trying to guess what it could be. Link to post Share on other sites
apd 0 Posted February 7, 2005 Report Share Posted February 7, 2005 if the plugs,leads are ok i'd check and clean the hall sender first.then have it code read.this is the tight git route as the coilpack is 150-200quid touch. Link to post Share on other sites
acf8181 0 Posted February 7, 2005 Report Share Posted February 7, 2005 Have just read this post' date=' and I can tell you that, I had to put my car in to AMD the other day, for similar problems, a couple of times it had developed a missfire usually from cold but more importantly it had felt like it had lost power. IT was put on diagnostics and I was told that they couldn't really find a cause for the missfire although the plugs were well passed their best, but also that they were getting a G40 sender/sensor? fault. This was replaced, fault dissapeared and in the words of the technician, it now feels like a different car. As ACF8181, has said, best to get it on diagnostics, it is the best way to tackle these sort of problems, as you could spend alot more trying to guess what it could be. [/quote']g40 sensor, thats the hall (or imulse) sensor isn't it? has same prob on mine, though it was actually the thing on the sproket thats had come apart not the sensor. Link to post Share on other sites
Pete.sVR6 0 Posted February 8, 2005 Report Share Posted February 8, 2005 Not sure mate, I know naff all about cars, have to rely on others to fix them when they go wrong. ~ Link to post Share on other sites
chufferman 0 Posted February 9, 2005 Author Report Share Posted February 9, 2005 just got back frtom vw main agents they were 9 codes came up they said that there was no actual electrical fault but on my way home thrashed it bo##ocks off it. then it came back alive and shot off like a rocket. will see how it goes these next few days? put a huge smile back on my face anyway. Link to post Share on other sites
