grom 0 Posted January 12, 2011 Report Share Posted January 12, 2011 as title. Ive had a poke around the site and found afew posts but no definative answers.does the filler neck detach from the tank?so i can clean and treat it indoors Link to post Share on other sites
Lukey. 381 Posted January 12, 2011 Report Share Posted January 12, 2011 no its entirely 1 piece youll have to do it in situe.theres a big metal ring under the round flap of rubber that holds it in place you need to remove that to get full access to the filler neck.While youre in there clean out the years worth of dirt that will have collected behind the rubber seal, i used a long screwdriver to loosen it then compressed air to blow it all out, there was tons in mine, watch out for the filler ground wire though you dont want to snap it,stick a big ball of masking tape tight in the filler neck and have at it.I sprayed the whole of the interior area with stonechip rubberised paint after id cleaned up the rust and dirt out to safeguard it happening again in a hurry Link to post Share on other sites
