FrostyCab 0 Posted January 16, 2011 Report Share Posted January 16, 2011 Need a bit of help guys.Was checking the oil and water today and spotted what looks like a water leak coming from the left hand side of the engine (Auxilary belt side) at the head gasket! haven't seen or found any other signs of it blowing and the car is running fine, not overheating at all.Getting worried that its on its way out but I'm not sure. whats everyone elses thoughts on this?How easy a job is this to do on the VR, done a few in my time but none involving timing chains, will i need any special tools? Link to post Share on other sites
FrostyCab 0 Posted January 20, 2011 Author Report Share Posted January 20, 2011 Anyone?? Link to post Share on other sites
bungy 2 Posted January 20, 2011 Report Share Posted January 20, 2011 First and foremost is it definately leaking from the block and not somewhere where condensation has gathered? I've recently done a 24v with VVT and if you have any experience it is no worse than setting the timing for a cambelt. Link to post Share on other sites
thegoth 5 Posted January 20, 2011 Report Share Posted January 20, 2011 A lot of VR lumps weep there. So yes, something to keep an eye on but no not necessarily a sign of an imminant failure. Link to post Share on other sites
probert993 0 Posted January 20, 2011 Report Share Posted January 20, 2011 are u sure its not leaking from the internal water pump , also check your core plugs i have had two fail in the last year put new ones in now Link to post Share on other sites
FrostyCab 0 Posted January 20, 2011 Author Report Share Posted January 20, 2011 Well, I checked it again this morning and its pouring out! Had to top her up with 1.5ltr of coolant.The final nail in the coffin was a check of the water hoses, hard as bricks and a massive whoosh of pressure when removing the expansion cap.Think I summed it up this morning in a word...Bugger!Ordered a new gasket from VW spares so its time to get grubby. real pain is I have to be in Kendal on Monday so looks like I'll be hiring a car!! Link to post Share on other sites
probert993 0 Posted January 20, 2011 Report Share Posted January 20, 2011 so its your head gasket for sure ? Mine always makes whoosh noise when removing lid, its only pressure isnt it? Is it leaking block for defo then Link to post Share on other sites
FrostyCab 0 Posted January 20, 2011 Author Report Share Posted January 20, 2011 The car was standing over night and cold so surely it shouldn't be holding pressure in the cooling system. Plus when she is running you can't compress the cooling hoses which means the exhaust gases are trapped.Just typical luck for me... just when I really need my car is decided to get sick! Link to post Share on other sites
