chief ka kar 0 Posted January 28, 2011 Report Share Posted January 28, 2011 I cant get a temp reading on my dash . I have change the thremostat i have replace the blue 2 pin sensor and the 4 pin yellow sensor. Which they gave me a brown one but i told them thats for air con models but he asured me it was the right one. Fitted the new sensor and my fans kicked in all the time. Took it back and he said you will have to go to vw. I rang them up they said we are not listing a 4 pin yellow part no 7019193698. So i now have a black 4 pin with a blue band around it and yes this one does'nt work.Does any one know which part no i need to replace the yellow 4 pin sensor.Thanks Link to post Share on other sites
chief ka kar 0 Posted January 28, 2011 Author Report Share Posted January 28, 2011 update, i now have a black sensor with the yellow band and still the same. I am stuck with this now i dont know why am not getting a reading on the dash or my fans wont kick in. Check all the fuses. Link to post Share on other sites
chief ka kar 0 Posted January 30, 2011 Author Report Share Posted January 30, 2011 Update i finaly got vag com to work with my car . I had a low voltage drop. Cleared the fault and fans are all working, just my dash is at fault at the mo but i will be pulling them out to see if i can find something wrong with them. Hope this helps some people out for future threads Link to post Share on other sites
makster28 0 Posted February 12, 2011 Report Share Posted February 12, 2011 whos vag.com mate how much do they charge to come out and have you got there bumber? cheers Link to post Share on other sites
legvw 0 Posted February 12, 2011 Report Share Posted February 12, 2011 Vagcom is diagnostics software which allows you to read read and clear fault codes etc. Link to post Share on other sites
makster28 0 Posted February 12, 2011 Report Share Posted February 12, 2011 how much os it to buy Link to post Share on other sites
legvw 0 Posted February 12, 2011 Report Share Posted February 12, 2011 VCDS is the upto date version of it, http://www.ross-tech.com/ Link to post Share on other sites
makster28 0 Posted February 12, 2011 Report Share Posted February 12, 2011 how much we taking to get kitted out Link to post Share on other sites
Madrocker 0 Posted February 27, 2011 Report Share Posted February 27, 2011 how much we taking to get kitted outI bought a lead from ebay for a tenner and downloaded the software for nothing. just had to mess around with a few scripts and it all worked well, but there is a free version of Vag-com that lets you read and clear codes Link to post Share on other sites
makster28 0 Posted March 5, 2011 Report Share Posted March 5, 2011 went into europarts today for the brown sensor which belongs in the thermo housing and the guy said its nothing to do with your aircon its called a thermo cooling senso,is he correct or is it for the air con like everyone says on here? Link to post Share on other sites
chief ka kar 0 Posted March 5, 2011 Author Report Share Posted March 5, 2011 It may be called that but it is linked to the aircon. I dont have aircon so therefore i have no brown sensor. Link to post Share on other sites
richievr 1 Posted March 5, 2011 Report Share Posted March 5, 2011 i don't know why they are struggling for you..the 4-pin sensor does the dash temp and aux water pump. part no 701 919 369 D SHOULD have sorted it for you, unless you have further issues somewhere. the replacement switches are no longer yellow, it should be black with a blue band.and you are quite correct - the brown one is air-con only.. Link to post Share on other sites
makster28 0 Posted March 5, 2011 Report Share Posted March 5, 2011 finaly got my fans working,it turned out to be 2 of the wires on the brown sensor clip were touching vag spotted the problem also changed the sensor,the fans kick in and turn on & off fine now but i am pretty certain its the stage 3 kicking in,and the temp is reading half way 90, does anyone know of some more checks i can do i changed the fan module and i am asuming it works or is stage 3 nothing to do with it? Link to post Share on other sites
makster28 0 Posted March 5, 2011 Report Share Posted March 5, 2011 i have heard my aux water pump but its not always on,should it be on everytime the engine is turned off mate? Link to post Share on other sites
richievr 1 Posted March 5, 2011 Report Share Posted March 5, 2011 i don't think so dude, i believe it to be temperature related.. Link to post Share on other sites
chief ka kar 0 Posted March 7, 2011 Author Report Share Posted March 7, 2011 I agree with richie Link to post Share on other sites
