terry 0 Posted January 28, 2011 Report Share Posted January 28, 2011 hi i have read a few threads regarding the 312mm brakes. i have the calipers, carriers, dics and pads. i have just ordered 40mm bolts.But i was wondering is there any one who sells the 6mm spacers that are needed of the shelf??cheers Link to post Share on other sites
Ben Seabrook 4 Posted January 28, 2011 Report Share Posted January 28, 2011 halfords Link to post Share on other sites
terry 0 Posted January 28, 2011 Author Report Share Posted January 28, 2011 cheers will have a look. Link to post Share on other sites
terry 0 Posted January 29, 2011 Author Report Share Posted January 29, 2011 sorry i didn't make it clear in my earlier post im after a 6mm spacer to sit between the hub and carrier. Link to post Share on other sites
CALICO 130 Posted January 29, 2011 Report Share Posted January 29, 2011 6mm washers should do Link to post Share on other sites
bungy 2 Posted January 29, 2011 Report Share Posted January 29, 2011 Make on yourself. Go to your nearest metal supermarket or your local equivalent and get some 6mm plate. Those type places will cut to a manageable size and that size will cost next to nothing. Angle grinder, jig saw and drill is all you need to make. Simples.... Link to post Share on other sites
terry 0 Posted January 30, 2011 Author Report Share Posted January 30, 2011 cheers for the replys Link to post Share on other sites
dubbed_up_daz 8 Posted January 30, 2011 Report Share Posted January 30, 2011 go to your nearest screwfix outlet...buy a pack of M12 stainless steel washers for @£3.80use four per bolt(theyre 1.5mm thick)job done....there is no need to spread the load with a full length spacer Link to post Share on other sites
terry 0 Posted February 2, 2011 Author Report Share Posted February 2, 2011 cheers Link to post Share on other sites
Antihero1981 8 Posted February 7, 2011 Report Share Posted February 7, 2011 will this effect the distance from the caliper to the wheel as with normal 288 discs my caliper is 2mm away from the wheel Link to post Share on other sites
Lukey. 381 Posted February 7, 2011 Report Share Posted February 7, 2011 it mmoves the calliper further out to go over bigger discs yes, you can fit standard wheels over them Link to post Share on other sites
