Gicho 0 Posted February 1, 2011 Report Share Posted February 1, 2011 im having a nightmare with the electric windows on my VR6 and was hoping someone , somewhere in here could help.Story so far, windows come down on their own and sometimes both of them together and sometimes just the one.I have diconnected the full closure side of the toad alarm just to eliminate this and they still do it. Sometimes they come down after a couple of days and sometimes ill get a week out of them.any ideas anyone as its driving me mad !For the love of God,if anyone can show me the light on this problem please come forward before someone steals my car.It always seems to open them at night,when its raining. The in side is soaking.ThanksGichopleeeaasse ! Link to post Share on other sites
tjsmudger 2 Posted February 1, 2011 Report Share Posted February 1, 2011 I had this problem, my central locking pump was crazy, the minute I went inside the house the windows went down, together. I was pulling my hair out thinking what it could. Im no whizz round a vehicle. I took all the wires off my battery terminals cleaned them then replaced. Not had a problem(touch wood) since! Link to post Share on other sites
Gicho 0 Posted February 1, 2011 Author Report Share Posted February 1, 2011 well,i've disconnected the battery altogether. This stops everything......including me driving the folking thing. Link to post Share on other sites
jesterwalker69 0 Posted February 1, 2011 Report Share Posted February 1, 2011 You checked the wiring in the door jams in the rubber casing?I had an issue with the drivers window randomly going down and up and then only working as and when it wanted too. Removed the rubber surround on the wires in the door jam and found one wire was pracitcally snapped!This turned out to be the window wire, once sorted it never happened again Link to post Share on other sites
Gicho 0 Posted February 1, 2011 Author Report Share Posted February 1, 2011 i've been told to check this rubber surround. Would this cause the problem in the passenger side as well?Gicho Link to post Share on other sites
tomjonesrs2 0 Posted February 21, 2011 Report Share Posted February 21, 2011 Hi Gicho, I have the same problem with my car and as yet have not found he problem. Tried disconnecting the alarm/immobliser system and checked wiring in doors but nothing has solved it.How are you getting on with yours, have you found the problem and if so what was it?Tom Link to post Share on other sites
CALICO 130 Posted February 22, 2011 Report Share Posted February 22, 2011 it can all be linked if you hold the key in the lock position on your door all the windows go up if held in the unlock they all go down as a temporary fix remove the fuse/fuses for the windows Link to post Share on other sites
chief ka kar 0 Posted March 3, 2011 Report Share Posted March 3, 2011 My drivers door stopped unlocking via alarm and the drivers window does'nt work not had chance to look at it yet. But when i unlocked the drivers door my passenger side window went down have way. Going to check the wires and see if its linked, (door not unlocking and window not working) Link to post Share on other sites
Gicho 0 Posted March 3, 2011 Author Report Share Posted March 3, 2011 I've disconnected everything. I don't worry about it anymore now. just don't have windows or an alarm. Link to post Share on other sites
stewvr6 0 Posted March 16, 2011 Report Share Posted March 16, 2011 I had this problem with mine,i used to find the passenger window opened whenever it fancied it. it is the earth wire in the door jam that has broken. With the door open the windows could be operated but with the door closed nothing worked including the sunroof. When i checked the cables in the rubber boot section of the drivers side door jam i found a thick earth wire had broken. an inline splice was fitted and i've never had a problem since. Link to post Share on other sites
Gicho 0 Posted March 16, 2011 Author Report Share Posted March 16, 2011 Good shout....I'll check that tomorrow....thanks for the reply...this thread is a little old and I didn't expect any more replies.Thanks again,Gicho Link to post Share on other sites
ex911driver 0 Posted June 22, 2011 Report Share Posted June 22, 2011 I had similar problem after leaving car at airport , had to drive from Stansted at 2 in the morning in Feb with all windows open.Turned out the microswitch in the door panel was playing up.Disconnected windowswitch and left for half hour ,reconnected and worked OK ever since Link to post Share on other sites
