vr6 sill lower plastic trims
genuine ones are all the same they only did one kind, do you mean the long strips that clip onto the tops?
these are part nos for those bits
1H0 853 985 Driver Side
1H0 853 986 Passenger Side
front end caps are separate and back ones are attached, so if your front ones are fine you can slide the strip out from under it without damaging it.
they are about £30 a side and are sided, the attached end cap goes to the back
