VR6 AUTO Any Ideas?
Hey all just got a new VR6 auto from a friend of a friend for just under £700
Posted this previously in another thread but obviously was the wrong place :)
It drives like a beaut and has been well looked after.
The guy said he added an induction kit which gave it an extra 5-10bhp was just wondering what people would recommended adding considering its an auto.
Budget up to £500 not looking for massive amounts of extra bhp but a lil bit would be nice
Cheers ladies and gents
well, cams and a remap .. should see you at just under 500 , depending on where you get them from
fyi, most induction kits do not add power , most lose it . hot air and all that . vw airboxs flow extremly well
secondhand cams can be had under 200 pounds, and a map circa 200-300 depending on if you need the cu socketing or not .
@jim potter
Thats what i wasnt sure about, what does an induciton kit actually include/ do
Sorry if i sound like a noob just very new to car modifications.
Cheers for the replys
Also another question albeit stupid one, VR6 arent supercharged are they and how easy would it be to do?
induction kit could be bracket and a cone filter.. thats the kit ..
other people buy a cone filter and make there own bracket.
pthers buy a replacemnt performance element for the standard air box..
when push comes to shove its what sort of sound you want .. cone filter can be noisy, panel filter less so.
superchargring aint to hard if you know who to bring it to . :)
That transporter wing vent would be good to feed air into a stock airbox for Turbo use :-)
If you want to spend 50 sheets, I would refit the factory airbox and replace all the chassis bushes to sweeten up the handling. I'm afraid 50 notes isn't going to give you much extra grunt as it's an Auto. They tend to sap too much throttle response anyway.
Hmmmmm.....
My left knee doesn't half ache when sat in traffic. All that up and down action on an uprated clutch and all that.
As I'm nearly 40, an auto box sounds might appealing! Probably not too bad to retro fit.
Only thing is, can it handle turbo grunt?
Turbo i am not sure about , the power from a charger is a bit more smoother than the kick from a Turbo .....only 1 way to find out hey! lol i built mine for daily driving so supercharger on a auto box seems a bit more relistic , she does get used and abused and its taken everything i have thrown at it
using over drive gears i reckon it is quicker than manual , no clutch and you can select next gear with a push of a button!smooth and effortless
will be better when i finish charge cooler and meth injection install
