you would need to make up a connector block using your existing wiring and the wiring for a H4 bulb X2
i would advise running a relay system to power the second set of bulbs as it may overload the original wiring running double what it was intended to run
  • 1 year later...
SUPER THREAD BUMP!!
I've got exactly the same problem, did this ever get resolved? I've got both headlights, one of which has a relay attached to the back of it, but that's it. No wiring harnesses or anything.
Funnily enough, this little detail was missing from the ebay description >:(. It could of course be a genuine mistake and the seller has forgotten to put them in the box, so I've sent him a message and will give him the benefit of the doubt until I hear otherwise.....
