grantnunn 0 Posted March 13, 2011 Report Share Posted March 13, 2011 Hi, ive posted a few post on this subject now and decided that as i have my oil pump sensors disconected then theres no point having an oil light flashing away at me o can anyone tell me if theres a wire i can disconecet or is there a bulb that will stop the light flashing, Cherrs all Link to post Share on other sites
VR6Pete 1,455 Posted March 13, 2011 Report Share Posted March 13, 2011 Why would you want to do that? Link to post Share on other sites
Madrocker 0 Posted March 13, 2011 Report Share Posted March 13, 2011 because he likes the noise of metal grinding. Seriously get a new oil sensor. Link to post Share on other sites
grantnunn 0 Posted March 14, 2011 Author Report Share Posted March 14, 2011 I dont know if it is the sensor though, can you get to the bulb through the dash? Link to post Share on other sites
Phat VR6 3 Posted March 14, 2011 Report Share Posted March 14, 2011 the oil pressure switch/ light is the most important part of you car to saving you hundreds of pounds and a full engine rebuild.id guess and eathing the wire that goes to the switch onto the block Link to post Share on other sites
Lukey. 381 Posted March 14, 2011 Report Share Posted March 14, 2011 they are flashing atm because your pressure senders are disconnected. Seriously wait til you get your new senders before doing anything else, you may cause new problems before you start down the path to the solution. Link to post Share on other sites
Madrocker 0 Posted March 14, 2011 Report Share Posted March 14, 2011 I dont know if it is the sensor though' date=' can you get to the bulb through the dash?[/quote']Seriously man its a very important light, if not the most important, the reason nobody has told you how to disconnect the light is for that exact reason. If you want to bodge things then buy a ford and talk to Mike brewer. Link to post Share on other sites
trackday 0 Posted March 15, 2011 Report Share Posted March 15, 2011 new sensors are about max 20 quid you can get them from vw or get a copy one from your local car parts place,replace it so you can make sure its not a oil pump problem as that could cost you £££££££££££ Link to post Share on other sites
