grantnunn 0 Posted March 17, 2011 Report Share Posted March 17, 2011 Hi all where does the oil warning buzzer noise come from? Link to post Share on other sites
ian_GTI 0 Posted March 17, 2011 Report Share Posted March 17, 2011 Theres a small buzzer inside the clocks mate Link to post Share on other sites
grantnunn 0 Posted March 17, 2011 Author Report Share Posted March 17, 2011 Ah, is there a way to disconnect it, i cant get the car in the garage for a few days and i know that the oil presure is fine? Link to post Share on other sites
ian_GTI 0 Posted March 17, 2011 Report Share Posted March 17, 2011 Not really mate You can take the clocks apart and put some tape over it at least it might quite it down Link to post Share on other sites
kentyboy 0 Posted March 17, 2011 Report Share Posted March 17, 2011 had the same problem on my old corrado,i just fitted an oil pressure gauge,then removed the buzzer,its a common fault on the corrados....its behind the rev counter clock..had the car for over three years like that,no problems at all,and the oil light still works as normal.. Link to post Share on other sites
grantnunn 0 Posted March 18, 2011 Author Report Share Posted March 18, 2011 How do you remove the dials guys Link to post Share on other sites
bpm 0 Posted June 1, 2011 Report Share Posted June 1, 2011 had the same problem on my old corrado' date='i just fitted an oil pressure gauge,then removed the buzzer,its a common fault on the corrados....its behind the rev counter clock..had the car for over three years like that,no problems at all,and the oil light still works as normal..[/quote']Is the fault with the clocks then? I've got the same issue with my mk2 trackcar Link to post Share on other sites
