makster28 0 Posted March 19, 2011 Report Share Posted March 19, 2011 i have done all the work on my car myself thanks to you lot on here so this next problem i will get around hopefully,driving the car at 90 degrees fans kick in loud and wont turn off but more scarier temp never drops below 90 so i suppose you cant blame um for kickin off,secondly is it possible for the main water pump to pack in without leaking water,iv got a bad feeling water aint circulating properly hoses have preasure etc,i know these engines get hot but surely the fans aint ment to blast all day long when driving?,cheers guys Link to post Share on other sites
Vw_owner 1 Posted March 20, 2011 Report Share Posted March 20, 2011 i have a similar problem, my temp guage doesnt get hotter then 75 and because of this my car runs rich because it thinks it cold, my m8 thinks its a thermostat {blue 2pin} as its for the ecu, well you could have the same problem but with the other thermostat,the 4 pin yellow? not sure, but there cheap to replace if they havnt been already,http://www.the-corrado.net/showthread.php?38925-The-definitive-VR6-cooling-guide&highlight=vr6+cooling+guide Link to post Share on other sites
Gazbarber1982 3 Posted March 20, 2011 Report Share Posted March 20, 2011 There both less than £10 each from VW. The yellow one has been replaced with a black one with a blue / green strip. It's for the fan control and for the aux. water pump. Link to post Share on other sites
makster28 0 Posted March 20, 2011 Author Report Share Posted March 20, 2011 cheers i will pick one up, i wernt going to bother as the aux water pump is ok but looks like the pin for the fans may of had it Link to post Share on other sites
Gazbarber1982 3 Posted March 20, 2011 Report Share Posted March 20, 2011 i have a similar problem' date=' my temp guage doesnt get hotter then 75 and because of this my car runs rich because it thinks it cold, my m8 thinks its a thermostat {blue 2pin} as its for the ecu, well you could have the same problem but with the other thermostat,the 4 pin yellow? not sure, but there cheap to replace if they havnt been already,http://www.the-corrado.net/showthread.php?38925-The-definitive-VR6-cooling-guide&highlight=vr6+cooling+guide[/quote']Plug it into vagcom and have a look at the coolant temp there compared to the gauge. The blue 2 pin sensor is ecu temp sensor, brown 4 pin is for air con and the yellow / black with blue strip 4 pin is temp sensor for gauge, fans and aux. water pump. Link to post Share on other sites
Vw_owner 1 Posted March 20, 2011 Report Share Posted March 20, 2011 m8 recons its the blue one telling the ecu porkie pies, got the sender ordered anyway as its cheap and i have no idea when it was last replaced, yea vag com would deffo help cheers gaz!! Link to post Share on other sites
makster28 0 Posted March 24, 2011 Author Report Share Posted March 24, 2011 ok not yet got the new sensors but today my temp reached 110 and i had to pull over and cool off this is the first time the car has got so hot, is there any known reason for this happening,basically it seems nothing is cooling the engine down whilst its moving temp only drops when turned off Link to post Share on other sites
makster28 0 Posted March 24, 2011 Author Report Share Posted March 24, 2011 sos craggsy your the man on here what you rekon fella Link to post Share on other sites
Vw_owner 1 Posted March 24, 2011 Report Share Posted March 24, 2011 have a butchers through the temp readings in here m8,http://www.the-corrado.net/showthread.php?38925-The-definitive-VR6-cooling-guide Link to post Share on other sites
Gazbarber1982 3 Posted March 25, 2011 Report Share Posted March 25, 2011 What was you doing when the temp got hot? (In traffic, givin it the beans??) Your thermostat could be goosed or your fans might not be kicking in. Link to post Share on other sites
makster28 0 Posted March 31, 2011 Author Report Share Posted March 31, 2011 fans kick in accordingly at past 90 and will not turn themselves off whilst the car is moving but if i pull over the fans will turn off after a few minutes then i will set off then there straight back on all the way through the drive,also fans will turn off when ignition is turned off i have no after run fans when the engine is turned off,cheers for coolant guide vr Link to post Share on other sites
Gazbarber1982 3 Posted March 31, 2011 Report Share Posted March 31, 2011 My fan used to kick in at 96'c on vagcom or 90'c on the gauge. Not checked into it too much recently as my fans kick in at 76'c on vagcom with no errors showing up but my over run works fine. You need your fan control module checking and replacing but try changing the sensors in the thermostat housing first. Also, there's about 7 different pin combinations for the control module (located under the header tank) so make sure you replace with the same part number. The last letter has no difference really apart from the earlier letter (a) is older than (e) It can brake if water gets in through the fuse cover. I had one go where it kept the aux. Water pump on permanently. Link to post Share on other sites
makster28 0 Posted March 31, 2011 Author Report Share Posted March 31, 2011 cheers i have changed the fan module for what i think is a working one and i did make the mistake of buying the wrong one at the start however i have a crusty contact on the big connector were the previous module blew on one of the pins,i have changed the brown sensor and am going to get the other 2 along with a new rad switch and see what happens Link to post Share on other sites
