jason2875 0 Posted March 19, 2011 Report Share Posted March 19, 2011 am in the process of fitting a new 6 branch and decat + o2 sensor removed all the about bits no probs although did have to grind the decat bolts off as they was all seized ,problem i am having is the connecter for the o2 sensor i removed seemed a bit of a mess wires cut etc then wrapped with tape,once i got it all apart the 3 wires as shown in the pic wasnt connected to the creamy connecter block does anyone know the order in which they should be connected or can they be left un-connected,can any one shed any light link to photoshttp://s511.photobucket.com/albums/s357/jason2875/manifold/ Link to post Share on other sites
stewvr6 0 Posted March 19, 2011 Report Share Posted March 19, 2011 That connector doesn't seem to be anything to do with the o2 sensor as that is conncted by the black block you have in the picture. Have you followed the wires from the connector to where it finishes up? If you can identify where it goes i might be able to find it in the bentley manual Link to post Share on other sites
jason2875 0 Posted March 19, 2011 Author Report Share Posted March 19, 2011 cheers stu no i havnt traced it back i assumed it was something to do with the o2 because it was all taped up together will have a look tommoro and get back to you Link to post Share on other sites
DanH 1 Posted March 20, 2011 Report Share Posted March 20, 2011 still think its the knock sensor.......fronts by the oil cooler, and 99% sure thats the rear. Link to post Share on other sites
jason2875 0 Posted March 22, 2011 Author Report Share Posted March 22, 2011 yes was the knock sensor might have a new rear one now so alls good Link to post Share on other sites
