Bought my vr6 last year in april and obsolutely loved it! but there was a few things needed doing to it and i was gonna sell it but i thought why not start a project!
Its a 2.8, has 2.9 corrado gearbox, 11mm HT leads, air filter and full stainless exhaust with decat.
Took it to santa pod and ran a 14.9 :)
heres the old girl
As you can see theres some rust issues! but thats gonna be sorted at some point :)
i jacked it up last year to have a look under neath and the jack went straight through the floor!!! i was gutted!
i got both new seals and welded up and a patch welded in the passenger rear footwell and also decided i want some more power.... so heres whats going in :D
Its a 2.8' date=' has 2.9 corrado gearbox, 11mm HT leads, air filter and full stainless exhaust with decat.
heres the old girl
Nice :) what plans you got for it?
im putting in the new turbo engine for a start :)
going to get the bodywork done when its back on the road so that'll be the last thing to do i guess.
thats gonna be doing the dent in the drivers door, rust on the passenger door, rear arches will need replacing and front wings replaced and front bumper will be painted as well cos the new bumper has been cut in places to make the intercooler pipes fit :)
the new front pipe i have is also to big to fit the old exhaust as its like twice the bore! :S
so im gonna get it big bore all the way through... yahooo :P
haha wicked :D keep updating the thread so we can see how you get on :) as and when ;)
will do' date=' have the front end of at the moment, but its going slow! gotta get the exhaust of and drive shafts then its pretty much ready to come out. measured exhaust, its 3" bore, so gonna have 3" all the way through :)
right the engine is in :D
but im having trouble now with a few things...
theres some plugs on the engine which i dont know where they go! and i have a fuel pressure gauge which i want to connect up but im not 100% sure what pipe goes where. there are two pipes coming from the fuel rail into the gauge and im guessing i just follow the pipes straight through..... any ideas people? :)
heres a video link
http://www.youtube.com/watch?v=Kjh_-f-yylU
well ive sorted the little green plug and the other 3 coloured plugs on the front of the engine now. (been 4 months since i stripped it all so its hard to remember where it all goes!! :P)
theres a brown plug at the top right hand corner of the engine which i have no idea where that goes! on my standard vr enginge i had before it didnt have that plug....
also on the engine i had before there was a plug at top left hand corner of engine where the throttle body was which plugged into the breather pipe on the air fitler pipe, but on this turbo engine theres a sort of like "air filter" there instead so theres no place for that plug to go.... does that mean any warning lights will come up on the dash?
one last thing is theres a black 2 pin plug at front of engine (seen in vid) and i dont know where that goes either! :S
i hope some1 can help! as i said i stripped it all at christmas time and memory is a bit crap.
Just wondering if the brown one has something to do with gearbox' date=' trying to remember as my vr being fixed so trying to remember myself lol, reverse switch maybe not 100% sure
Nathan
yeh ive got the reverse switch plugged in, think its the right one anyway :)
right engine is running!! :D
i havent finished it yet but i thought i'd start it up and see if it worked.... which it did :)
no warning lights are up, just the battery light as my battery is dead! so will have to get another one of them.
things to do:
driveshafts need to go in
needs antifreeze
gearbox oil
power steering fluid
the rest of the intercooler pipes need to go on (but am having trouble trying to figure out how there going to go! especially since theres no room for the air filter and battery!
the smaller pipes need plugging onto wastegate and air pipes etc.... then its putting the interior back together (since i had welding done) and then start on the bodywork!
my god it never seems to end does it!
oh and i need to get an exhaust made for it :P
i will try get some pics! buts it not looking to healthy at the moment :(
tried putting driveshafts in today but need to lever the engine forward as i cant swing the driveshaft in.
Antifreeze is done and gearbox oil is done.
Trouble i have now is the oil light has come on :S
when i first started engine all was well, next day i started it the oil light came up, checked oil level and it was well low! i filled up oil and light went out.
but then today light has come on again, oil level is ok though.... havent touched anything to affect oil, or switches etc :S any ideas guys?
also having trouble trying to get intercooler pipes to fit and a bit confused on the piping for the wastegate and air filter etc. they look like bleed nipples with banjo bolts going through them
there is one nipple on the dump valve, one on the piping coming from the throttle body to the dump valve, another 2 nipples on the wastegate (one on the side of the wastegate and one on the top of the wastegate) and another sort of "pipe" coming out from the throttle body area. these all have to be linked somehow with these flexie pipes i have but have no clue how they go.
can you tell i havent had any experience with turbos? haha :)
would appreciate any help guys! im struggling!
