gary_auto 1 Posted April 6, 2011 Report Share Posted April 6, 2011 I got like a missfire but dont think it is. got new ht leads . think its somethink todo with my ideling?? was going try clean my isv but cant seem to find it (obd2) so now going try a new 2nd INLET MANIFOLD+THROTTLE BODY.can anyone help Link to post Share on other sites
cabrioman 6 Posted April 6, 2011 Report Share Posted April 6, 2011 OBD2 does not have a seperate isv like the OBD1 ... have you had the throttle body off ??? if so let the car idle for about 3-4 to try and re-set it ..... th eidle will be rough but should smooth out Link to post Share on other sites
Vw_owner 1 Posted April 6, 2011 Report Share Posted April 6, 2011 idd check to see if the ht leads are correctly seated, Link to post Share on other sites
tjsmudger 2 Posted April 6, 2011 Report Share Posted April 6, 2011 As aboveIf you have put the leads in by hand they can sometimes be tricky to seat correctly! Link to post Share on other sites
gary_auto 1 Posted April 6, 2011 Author Report Share Posted April 6, 2011 Iv had the inlet off to try a clean the throttle body but made it worse. it was missfireing befor but after new ht leads that went but still had the idle misfire?? Link to post Share on other sites
Gazbarber1982 3 Posted April 6, 2011 Report Share Posted April 6, 2011 If you unplug the throttle body it loses it's adaption and needs to be adapted. Either done through vagcom or without touching the accelerator pedal, turn the ignition to on without starting and leave it for 5 mins. There the only ways to adapt your throttle body and could cure idleing Link to post Share on other sites
gary_auto 1 Posted April 6, 2011 Author Report Share Posted April 6, 2011 If you unplug the throttle body it loses it's adaption and needs to be adapted. Either done through vagcom or without touching the accelerator pedal' date=' turn the ignition to on without starting and leave it for 5 mins. There the only ways to adapt your throttle body and could cure idleing[/quote']Thanks! I will try this tomorow. i have vagcam but not sure how i would go about doing that so ill try and leave it for 5mins 1st. I did have a error code come up on vagcom ( Idle Speed Regulation_ but since taking off and putting aback on its gone. maybe it will come back after the throttle body does its thing Link to post Share on other sites
Gazbarber1982 3 Posted April 6, 2011 Report Share Posted April 6, 2011 If you got vagcom you goto engine controller and then basic settings group 098. Takes 3 seconds to adapt. In block 4 it will say adapt run then adapt OK. If your using eBay vagcom and your not setup right, you might get adaption error but it can be done ;-) Link to post Share on other sites
gary_auto 1 Posted April 6, 2011 Author Report Share Posted April 6, 2011 If you got vagcom you goto engine controller and then basic settings group 098. Takes 3 seconds to adapt. In block 4 it will say adapt run then adapt OK. If your using eBay vagcom and your not setup right' date=' you might get adaption error but it can be done ;-)[/quote']Got ya Thanks Nother quick question tho does my obd2 engine have a isv if so ware is it? Link to post Share on other sites
Gazbarber1982 3 Posted April 6, 2011 Report Share Posted April 6, 2011 Not got them on obd2. It's built into the throttle body. Link to post Share on other sites
gary_auto 1 Posted April 7, 2011 Author Report Share Posted April 7, 2011 Ok thanks. btw as you seem to know alot about vag-com is there any tricks i can do with it to my car???? cant seem to find any links on it. the only thing i no how to do is read fault codes Link to post Share on other sites
Gazbarber1982 3 Posted April 7, 2011 Report Share Posted April 7, 2011 Not too much you can do really. Clear fault codes, throttle body adaption, bleed abs pump. When you clear the fault codes for the engine it resets all the learnt values for your engine so will need to learn them again. Link to post Share on other sites
gary_auto 1 Posted April 7, 2011 Author Report Share Posted April 7, 2011 Ohh how do i bleed the abs pump? Link to post Share on other sites
Gazbarber1982 3 Posted April 9, 2011 Report Share Posted April 9, 2011 Ohh how do i bleed the abs pump?Open the abs controller on vagcom, click basic settings and go to group 1 and follow instructions. Link to post Share on other sites
