michael5556 247 Posted April 10, 2011 Report Share Posted April 10, 2011 I have a blown head gasket and have the "Mayo" and I am fixing it this week, new bolts etc, but I was wondering what's the best way to get rid of this? Is it to take everything out and get it all cleaned etc? Or can I just use some engine flush solution etc?Any solutions welcome.Many thanks. Link to post Share on other sites
Bobtrude 0 Posted April 10, 2011 Report Share Posted April 10, 2011 I dont know if my technique is the best but I drained my system and stuck a gardenhose in one tube while i kept the one on the other side of the engine open. Did this with several different tubes. Then i filled the engine with clean water, started it and drained it after the thermostat had opened and the whole engine had circulated the water.Did this approx 4 times, then filled it with vw coolant... Link to post Share on other sites
Lukey. 381 Posted April 10, 2011 Report Share Posted April 10, 2011 if youre on about mayo in the oil after a headgasket then dont do anything, just drain as much as you can then with the HG fixed and good as new fill with new oil and go for a long drive, as you want to get the engine good and hot for a long time to burn off the moisture in the oil ways which will then make its way out of the engine through the crankcase breather Link to post Share on other sites
michael5556 247 Posted April 10, 2011 Author Report Share Posted April 10, 2011 Ok cool will do that then, thanks. Link to post Share on other sites
