vw28bl 0 Posted April 10, 2011 Report Share Posted April 10, 2011 Any one had issues with idle speed being too high when engine is at normal running temp? my 96 vr has just started doing this since i changed the temp sensor due to cold running problems ie nearly stalling all the time.symptons are after pulling up at a junction too a complete stop the rpm sticks at around 2k for 2-3 seconds then gradually goes down to normal 800rpm.I havnt got any fault codes logged, any suggestions?? Link to post Share on other sites
legvw 0 Posted April 11, 2011 Report Share Posted April 11, 2011 Try reseting your ecu. Unplug the battery for a few minutes, then re-connect it, switch ignition on for a minute, start it and leace it to run for 5 minutes without touching throttle etc. Link to post Share on other sites
VR6Gill 1 Posted April 11, 2011 Report Share Posted April 11, 2011 Could it be the crank case breather? Link to post Share on other sites
vw28bl 0 Posted April 11, 2011 Author Report Share Posted April 11, 2011 Never given it a thought, couldbe I suppose, although it is ok until the engine warms up,still wortha lol though. Link to post Share on other sites
Bobtrude 0 Posted April 14, 2011 Report Share Posted April 14, 2011 Check your oil filler cap. If its loose it can give you idle problems. Link to post Share on other sites
vw28bl 0 Posted April 14, 2011 Author Report Share Posted April 14, 2011 I'll do that, one thing I noticed was some oil under the air intake pipe where the engine breather joins on, could be drawing air in I suppose. Link to post Share on other sites
Bobtrude 0 Posted April 15, 2011 Report Share Posted April 15, 2011 yes and it would fool the maf.... Link to post Share on other sites
MJ Vr6 79 Posted April 15, 2011 Report Share Posted April 15, 2011 Any one had issues with idle speed being too high when engine is at normal running temp? my 96 vr has just started doing this since i changed the temp sensor due to cold running problems ie nearly stalling all the time.symptons are after pulling up at a junction too a complete stop the rpm sticks at around 2k for 2-3 seconds then gradually goes down to normal 800rpm.I havnt got any fault codes logged' date=' any suggestions??[/quote']Sounds like MAF mate.Double check first, disconnect and start the car, initial reaction when starting will be a bit lumpy till ECU realises, then drive the car and see if the problem consists.Will be running on limp mode.You should be able to see that the car runs better.If thats the case then change the MAF, you do not need vag com to reset anything, drive the car for around 8miles then the new MAF will reset itself.If your finding oil in the Intake Pipe, clean your Throttle at the same time.Hope this helps.8-) Link to post Share on other sites
vw28bl 0 Posted April 17, 2011 Author Report Share Posted April 17, 2011 Hopefully sorted now, took the intake duct off and found the breather unit had just about parted company with the rubber hose that comes off the top of the rocker cover, quick clean up and a dab or two of super glue as a temp fix seems to have sorted it. Anyone know if the breather is available seperate to the intake ducting? Link to post Share on other sites
MJ Vr6 79 Posted April 19, 2011 Report Share Posted April 19, 2011 Ford sell them dude..! NO JOKE!! Link to post Share on other sites
vw28bl 0 Posted April 19, 2011 Author Report Share Posted April 19, 2011 Cheers I'll give them a try. Link to post Share on other sites
