noscharged 0 Posted April 23, 2011 Report Share Posted April 23, 2011 I have recently sold my supercharged vr6 to a friend of mine(as I've bought another). He wants to fit a boost gauge and oil temp gauge to it.First of all, is it possible to fit a boost gauge to it, if so where does it connect to? Ie what vacuum line. And also where is the oil temp sensor? Any help would be great guys. Link to post Share on other sites
legvw 0 Posted April 23, 2011 Report Share Posted April 23, 2011 You should be able to plumb the gauge onto the brake servo vac line, onto the nipple furthest from the brake servo.The oil temp sender is on the back left on top of the oil filter housing. Or you could use the original vw wiring, and find which wire comes from the sender to the clocks, as i did on my car. Saves running extra cable that way. Link to post Share on other sites
