cliveyp 0 Posted February 17, 2005 Report Share Posted February 17, 2005 The last bit that i need to get before i start installing all of my gear is speaker cable. What size are you guys running? I can't remember what i've had in the past as it's been swapped from one car to the next, but this time i left it in the car when i sold it, meaning i need to buy new. I've had a look at the cables express website as recommended by Pedrox, but they only go to 2x2.5mm2 and i'm sure i've used bigger than that in the past. %-6 Link to post Share on other sites
acf8181 0 Posted February 17, 2005 Report Share Posted February 17, 2005 good luck feeding it through the door plug...thats why i kept with the standard stuff. Link to post Share on other sites
CORR VR 0 Posted February 17, 2005 Report Share Posted February 17, 2005 Thickness of cables doesn't necessarily give an increase/decrease in sound quality if thats what you're after. Look at the quality of the cable before you buy. I got some QED cable for my home system which was the same size as the cable replacing and the difference was amazing. It was £5 a meter though. Link to post Share on other sites
PEDROX 0 Posted February 17, 2005 Report Share Posted February 17, 2005 It depends on how much power your running through,if you running 6.5" in the doors they wont be more than 100 rms so the 2.5mm should be good for that.but obviously you will need phat cable for your subs Link to post Share on other sites
