spadam 7 Posted February 14, 2012 Author Report Share Posted February 14, 2012 Took my wheels to have the tyres fitted today and the tyre placed rufused as they said the paint was to soft and would chip of around the edge.They have been left to cure for 3 weeks in a heated house ???? Link to post Share on other sites
legvw 0 Posted February 14, 2012 Report Share Posted February 14, 2012 Did you spray the wheels whilst they were cold? Link to post Share on other sites
spadam 7 Posted February 14, 2012 Author Report Share Posted February 14, 2012 They shouldnt hsve been to cold as they were in the house before hand. Maybe there were a bit cold. Guns try sonewhere else if they get scratched will just have to touch them up. Link to post Share on other sites
bungy 2 Posted February 15, 2012 Report Share Posted February 15, 2012 At least the tyre place were concious of trashing your wheels rather than just go ahead and trash them. Link to post Share on other sites
bungy 2 Posted February 15, 2012 Report Share Posted February 15, 2012 If you want to talk through the detailing give me a ring or pop round. Could try out some samples of stuff I have if you want. Link to post Share on other sites
spadam 7 Posted February 15, 2012 Author Report Share Posted February 15, 2012 Tyres are now fitted and i like the look a lot now to fit the tyres this weekend as have soneone coming to collect my santa monicas.Mark will take you up on that offer going to borrow jakes pressure washer and clay the car then shall pop rnd when suits you. Link to post Share on other sites
hvr6 88 Posted February 16, 2012 Report Share Posted February 16, 2012 send me a pic Adam Link to post Share on other sites
spadam 7 Posted February 16, 2012 Author Report Share Posted February 16, 2012 Do you need to check i will be allowed in the halls lolWill send one over shortly Link to post Share on other sites
hvr6 88 Posted February 16, 2012 Report Share Posted February 16, 2012 lol I just want to have a sneak preview... Link to post Share on other sites
hvr6 88 Posted February 16, 2012 Report Share Posted February 16, 2012 and we're putting nee naw in there yours will be fine!!! I can't stop laughing about the display plans for that!! Link to post Share on other sites
spadam 7 Posted February 16, 2012 Author Report Share Posted February 16, 2012 Haha yea i cant wait till we drive out and theres a puddle of oil lol Link to post Share on other sites
spadam 7 Posted February 18, 2012 Author Report Share Posted February 18, 2012 Wheels are on but i choose the wrong tyre size and they look lost in the arches. Like the colour but wheels looks to small so pissed off at the mo. Let me know your opions good or bad.On the plus side recieved a tax rebate. Link to post Share on other sites
bungy 2 Posted February 18, 2012 Report Share Posted February 18, 2012 What size did you go for?Isn't the yellow dot supposed to go over the valve on a pre-balanced tyre? Link to post Share on other sites
spadam 7 Posted February 18, 2012 Author Report Share Posted February 18, 2012 Not sure didnt know that map pop back and ask them then.Ended up going 205 40 17 which are far to small for those arches. To late now though so rather annoyed with it all. Link to post Share on other sites
bungy 2 Posted February 18, 2012 Report Share Posted February 18, 2012 I have 225/45/17's on mine and they seem ok. 40% of 205mm is a lot different to 45% of 225mm which is where the difference is. Maybe strike a deal with Tony for his as yours will fit a mk3 better. Link to post Share on other sites
craggsy 91 Posted February 18, 2012 Report Share Posted February 18, 2012 205/40 17s are ideal on a mk3.Id go as Bunny says as mine are 225/40 18s which is right as a step up in size is a step back in profile Link to post Share on other sites
spadam 7 Posted February 18, 2012 Author Report Share Posted February 18, 2012 Yea may have a word with tony and see what he says. Link to post Share on other sites
spadam 7 Posted February 18, 2012 Author Report Share Posted February 18, 2012 Should have done more research nevermind Link to post Share on other sites
legvw 0 Posted February 18, 2012 Report Share Posted February 18, 2012 I did offer you my tyres that I'm selling, would have been fine. Still, wheels look quite cool against your body colour. Link to post Share on other sites
spadam 7 Posted February 21, 2012 Author Report Share Posted February 21, 2012 New tyres order and being fitted this week.Still need to get ceaning though so hope it starts getting light after work Link to post Share on other sites
spadam 7 Posted February 23, 2012 Author Report Share Posted February 23, 2012 Well some pics of this weekends antics.What supposed to be a simple job turned into a whole days nightmare. Took about an hour to even get the car in the air as tye car was to low for the ramp so had to drive onto blocks of wood to be able to get the arms under the car. staryed stripping down the passenger side which was easy all off and rear trailing arm bush removed within 40mins.Then onto the drivers side.......Well the first off after a little bit of wiggiling we noticed a leaking brakline which turned up to be snapped. So carried on and removed trailing arm bracket. Next came the bolt through the bush itself this was well and truly siezed and eventually snapped. After a few swear words a quick call to paul we were told to remove the rear arm and take it up to parkys workshop. This didnt quite go to plan as the bolts to the tie arms had been fitted the wrong way round meaning we needed to remove the rear caliper to remove the rear arm. The first caliper carrier bolt was removed with ease and you guessed it the second bolt snapped of in the carrier. Parky worked his magic with his grinder and palsma cutter and managed to remove the nut and bolt on the inside of the trailing arm bush. pic of parkys magic welding.Parky then used more magic in the way of huge flames and welded a nut on the snapped caliper bolt and heated it up so it could be removed. He then removed a carrier bolt of his own car so we could get the car back together that day. Me and jake then set about greasing all our nuts and refitted everything. We then had the fun of reflaring the broken brakeline and fitting a new union. Well car was all back together and back on the road by 5pm. Couldnt of done it without Jake and Parkys help and the use of daves ramp. Best get my carbon vinyl roof sorted this weekend and get some serious cleaning done. Link to post Share on other sites
cornishvr6 52 Posted February 23, 2012 Report Share Posted February 23, 2012 Liking the colour choice on the wheels, Im Very interested on how the roof turns out Link to post Share on other sites
spadam 7 Posted February 23, 2012 Author Report Share Posted February 23, 2012 Yea so am i hoping it goes well and looks good. Wish i had the money to chuck it into the bodyshop but that will be later in the year and i will also get the wheels done properly at the same time as i really like the colour but its not perfect as it was all diy. Link to post Share on other sites
Caddyslammed 16 Posted February 23, 2012 Report Share Posted February 23, 2012 good work mate Link to post Share on other sites
spadam 7 Posted February 26, 2012 Author Report Share Posted February 26, 2012 Busy day today doing the carbon vinyl roof. Definetly 100 times harder than the interior parts thats for sure. Few pics of how it looks after 4hrs on it. Still got a few bubbles which i need to heat up and pop with a pin. Still debating wether to rip the vinyl of but think it may damage the paint now so going to try and pop the bubbles as best i can. Link to post Share on other sites
