Tony20vturbo 0 Posted April 29, 2011 Report Share Posted April 29, 2011 Hi GuysI bought a VR6 the other day and it has got an overheating issue, it also has a slight leakFirst problem:I have done some searching on overheating, and it appears it is the thermostat, as the coolant is staying as it should (therefore not just disappearing which suggests a head gasket issue), but it just gets hotter and hotter, to the point where the coolant is starting to smell burntWhere is the best place to get a replacement thermostat? some people say Awesome GTI as the ones from GSF are badly built, leak and fail. If so, is this the right one:http://www.awesome-gti.co.uk/product.php?xProd=5589&xSec=129and does it just plug straight in (also where does it go?)Second problem:There is a slight leak, now I thought it was from one of the hoses but it appears it is coming from a brown sensor which is plugged into the block. If I wiggle it a bit, it starts to drip slowly. Anyone know what this sensor is? I am guessing the rubber seal has perished on it, and will need a new clip alsothanks for the helpTony Link to post Share on other sites
bungy 2 Posted April 29, 2011 Report Share Posted April 29, 2011 Take the thermostat out and heat it up in a pan of water and see if it opens and at what temperature. Link to post Share on other sites
michael5556 247 Posted April 29, 2011 Report Share Posted April 29, 2011 Yeah sounds like thermostat to me! Link to post Share on other sites
Tony20vturbo 0 Posted April 29, 2011 Author Report Share Posted April 29, 2011 Thanks guysAnyone know what the brown sensor is plugged into the bottom right hand corner of the block? Link to post Share on other sites
craggsy 91 Posted April 29, 2011 Report Share Posted April 29, 2011 Brown sensor plugs into the thermostat housing and is for aircon i do beleive.Do you have aircon/climate? Link to post Share on other sites
Tony20vturbo 0 Posted April 29, 2011 Author Report Share Posted April 29, 2011 Brown sensor plugs into the thermostat housing and is for aircon i do beleive.Do you have aircon/climate?thanks mateSensor seems fine, its just leaking very slightly from this, so I guess the clip and rubber seal round this has perished Link to post Share on other sites
Tony20vturbo 0 Posted April 29, 2011 Author Report Share Posted April 29, 2011 is this the correct housing?http://cgi.ebay.co.uk/VW-MK3-GOLF-CORRADO-PASSAT-VR6-THERMOSTAT-HOUSING-/140524906018?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item20b7efe622I am guessing I would need a gasket which goes between this and the block?Thanks Link to post Share on other sites
