allan m69 0 Posted May 9, 2011 Report Share Posted May 9, 2011 please can anyone help,ive rounded of the head on the alen key bolt that holds the power steering res to the battery plate?*-) Link to post Share on other sites
DanH 1 Posted May 9, 2011 Report Share Posted May 9, 2011 i hammered a torx bit in there...but i'm an animal,,,, Link to post Share on other sites
michael5556 247 Posted May 9, 2011 Report Share Posted May 9, 2011 Either try hammering a torx bit in like dan said or put your Allen key in, get a massive set of mole grips and tighten them as tight as you can, it will crush the bolt around the allen key and it should turn out Link to post Share on other sites
allan m69 0 Posted May 9, 2011 Author Report Share Posted May 9, 2011 ive tryed that,not working????? proper doing my head in.. Link to post Share on other sites
michael5556 247 Posted May 9, 2011 Report Share Posted May 9, 2011 Try hammering a bigger one in? Link to post Share on other sites
Gazbarber1982 3 Posted May 9, 2011 Report Share Posted May 9, 2011 Set of footprints or 6" stillies on the outside of it. That's how I got my bolts out of the rear brake caliper! Replaced with new bolts and covered the head in copper grease so they last a bit longer. Link to post Share on other sites
russj249 2 Posted May 9, 2011 Report Share Posted May 9, 2011 if nothing's flammable around the area, heat it up till it's hot with a descent blow torch (like a rothenberger torch if you can get hold of one), then do the Torx trick. Never failed me yet.Obviously remove the battery 1st lol. Link to post Share on other sites
apd 0 Posted May 9, 2011 Report Share Posted May 9, 2011 grind/file it flat and the use mold grips? Link to post Share on other sites
sharma187 0 Posted May 9, 2011 Report Share Posted May 9, 2011 Drill it out and then nut and bolt it. Link to post Share on other sites
allan m69 0 Posted May 10, 2011 Author Report Share Posted May 10, 2011 thanks guys Link to post Share on other sites
