VR6-DUB 3 Posted May 15, 2011 Report Share Posted May 15, 2011 Check the 2 links belowhttp://cgi.ebay.co.uk/VW-GOLF-MK3-VR6-STAINLESS-STEEL-EXHAUST-RACE-MANIFOLD-/140547930254?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item20b94f388ehttp://cgi.ebay.co.uk/VW-GOLF-MK3-GTI-VR6-STAINLESS-STEEL-EXHAUST-MANIFOLD-/120725261870?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c1bc94e2eor is better to save up for a raceland manifold? or like wise?Want your guys opinionsCheers. Link to post Share on other sites
Antihero1981 8 Posted May 16, 2011 Report Share Posted May 16, 2011 not seen them before they might be copies .......better to buy once i would say!i have owned only raceland manifolds on all my cars and cant complain.....i say buy the raceland one , fit it once....! Link to post Share on other sites
VR6Pete 1,455 Posted May 16, 2011 Report Share Posted May 16, 2011 Agreed. Never had a single problem with my raceland on any of my cars now... Link to post Share on other sites
VR6-DUB 3 Posted May 16, 2011 Author Report Share Posted May 16, 2011 Ok guys where can i buy a raceland manifold from? at a very good price :-) Link to post Share on other sites
hawwy 0 Posted May 16, 2011 Report Share Posted May 16, 2011 what power increse does a 6 branch give? Link to post Share on other sites
spindat45 0 Posted May 16, 2011 Report Share Posted May 16, 2011 I got a Hottuning manifold from Strictly Dubs http://www.strictlydubs.com/Contact.html a couple of years ago. Might be worth giving them a call and seeing what they can do. At the time, we got them for £150 each.The first link you put up looks almost identical to the Raceland/Hottuning one but difficult to tell the quality from a picture. i'd strongly recommend heat wrapping it. I used this wrap http://cgi.ebay.co.uk/HEAT-TREATED-EXHAUST-WRAP-50MM-X-20M-LONG-SST-/260721215467?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cb43207eb soaking it in water before makes it a lot easier to do http://i273.photobucket.com/albums/jj201/spindat45/110920091931.jpg. At the very least, replace your front engine mount if it's old as excessive engine movement often results in the manifold cracking. The manifold gasket's that came with mine were thin so I got some from GSF or Eurocarparts. Hope some of this helps.Kevin Link to post Share on other sites
spindat45 0 Posted May 16, 2011 Report Share Posted May 16, 2011 what power increse does a 6 branch give?Approximately 10-15 bhp but more of a raspy sound to the exhaust note Link to post Share on other sites
VR6-DUB 3 Posted May 17, 2011 Author Report Share Posted May 17, 2011 I got a Hottuning manifold from Strictly Dubs http://www.strictlydubs.com/Contact.html a couple of years ago. Might be worth giving them a call and seeing what they can do. At the time' date=' we got them for £150 each.The first link you put up looks almost identical to the Raceland/Hottuning one but difficult to tell the quality from a picture. i'd strongly recommend heat wrapping it. I used this wrap http://cgi.ebay.co.uk/HEAT-TREATED-EXHAUST-WRAP-50MM-X-20M-LONG-SST-/260721215467?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cb43207eb soaking it in water before makes it a lot easier to do http://i273.photobucket.com/albums/jj201/spindat45/110920091931.jpg. At the very least, replace your front engine mount if it's old as excessive engine movement often results in the manifold cracking. The manifold gasket's that came with mine were thin so I got some from GSF or Eurocarparts. Hope some of this helps.Kevin[/quote']Hey nice 1 Kevin good info and links there definetly love your pic of the manifold very nice and neatly done i like it, also where did you get your metal cable ties from? cheers. Link to post Share on other sites
VR6-DUB 3 Posted May 17, 2011 Author Report Share Posted May 17, 2011 Also i have a milltek decat and cat back system fitted already does the manifold bolt straight on to the decat pipe? Link to post Share on other sites
spindat45 0 Posted May 18, 2011 Report Share Posted May 18, 2011 My cousin ordered a pack of the cable ties from ebay. Lots left over but they come in handy. It does take a while to get it wrapped properly but it's worth it. Try to overlap half the width of the wrap each time so it doesn't separate. I had an Ebay decat and Miltek exhaust which bolted straight to the 6 branch so I don't think you'll have any problems there. Link to post Share on other sites
VR6Pete 1,455 Posted May 18, 2011 Report Share Posted May 18, 2011 It says on the eBay link for the heatwrap FREE 8 x Stainless Steel Ties 6mm Wide x 360mm Long FREEWouldn't have thought you'd need more than 8? Link to post Share on other sites
FishWick 21 Posted May 18, 2011 Report Share Posted May 18, 2011 I'd love to try one of these some day - http://www.spturbo.com/onlinestore/index.php/vw/mk3/vr6/exhaust/the-ultimate-vr6-exhaust-header.html10hp and 15lbft gain - to the wheels!! Link to post Share on other sites
spindat45 0 Posted May 18, 2011 Report Share Posted May 18, 2011 It says on the eBay link for the heatwrap FREE 8 x Stainless Steel Ties 6mm Wide x 360mm Long FREEWouldn't have thought you'd need more than 8?Hi Pete. Pat used up the 8 in no time when he wrapped mine http://i273.photobucket.com/albums/jj201/spindat45/110920091931.jpg. Depends how neat you want it I guess and if you wrap the pipes individuallyKevin Link to post Share on other sites
VR6-DUB 3 Posted May 18, 2011 Author Report Share Posted May 18, 2011 Thanks for the info guys, kevin might have to get your cousin Pat to do mine love it looks neat and professional :-) Link to post Share on other sites
Antihero1981 8 Posted May 19, 2011 Report Share Posted May 19, 2011 stainless wire works just as good and most heat wraps come with it for free Link to post Share on other sites
paulbin 0 Posted May 26, 2011 Report Share Posted May 26, 2011 I have got one of the manifolds in the first link, it has a plate saying it's a toyosport make. I've compared it to pictures of raceland manifolds and they seem to be the same. It came with all good gaskets, adapters to fit the cat and spring bolts to put it all together. I was very pleased with the quality and haven't had any problems to far. Link to post Share on other sites
ryanmac 0 Posted May 28, 2011 Report Share Posted May 28, 2011 I used to run a solid front engine mount on my mk2 with the 4 branch manifold. If the 6 branch manifold is fitted do any companies produce a solid front engine mount for the vr6? Link to post Share on other sites
Antihero1981 8 Posted May 29, 2011 Report Share Posted May 29, 2011 yeah you can get a solid one off ebay , think about 80 quid ....... Link to post Share on other sites
23345matt 0 Posted May 29, 2011 Report Share Posted May 29, 2011 This guy normally has them, for about 48 quid, may be owrth emailing him and seeing if he has anymore.http://myworld.ebay.co.uk/pigeon-computing/?_trksid=p4340.l2559 Link to post Share on other sites
23345matt 0 Posted June 12, 2011 Report Share Posted June 12, 2011 Just bought myself a raceland 6 branch and decat. Just wondered if there will be any gain in fitting now as I still have a standard exhaust system as I want it to keep the car looking original. Car has 2.9 inlet mani and ram air filter already and 2.9 throttle body to Link to post Share on other sites
