bentheboffin 1 Posted May 18, 2011 Report Share Posted May 18, 2011 hi does anyone know which lambda sensor goes on the exhaust down pipe? its the primary lambda sensors (5 pin ones) one has a brown connector, the other has a black connector. Link to post Share on other sites
bungy 2 Posted May 19, 2011 Report Share Posted May 19, 2011 I can look for you later as I have a spare down pipe at home with lambdas in. Link to post Share on other sites
bentheboffin 1 Posted May 19, 2011 Author Report Share Posted May 19, 2011 if you could look that'll be great Link to post Share on other sites
bungy 2 Posted May 21, 2011 Report Share Posted May 21, 2011 Mine are both 6 pin connectors with 5 wires connected. Do you need the numbers stamped on the actual lambda? Link to post Share on other sites
bentheboffin 1 Posted May 21, 2011 Author Report Share Posted May 21, 2011 All I need to know is which one is for what cylinder?Eg lanbda with brown connector for cylinders 1,2 and 3 Link to post Share on other sites
bungy 2 Posted May 21, 2011 Report Share Posted May 21, 2011 these are positioned in their true orientation. Link to post Share on other sites
bentheboffin 1 Posted May 21, 2011 Author Report Share Posted May 21, 2011 cheers bungy for posting that, you are a star Link to post Share on other sites
