ryanmac 0 Posted May 23, 2011 Report Share Posted May 23, 2011 Hi allI am new to the forum and to owning a vr6 but I picked this up for a couple of hundred pounds. Its going to be my weekend toy/track car.Its got lots of history and a few mods already. The guy that had it previously fitted 312mm brakes, 17" alloys , coilovers and a stainless steel exhaust. It did have an electrical problem behind the dash so I have had to rewire it but hopefully it will work. Link to post Share on other sites
grandmstramrod 0 Posted May 23, 2011 Report Share Posted May 23, 2011 nice mate looks beautiful! Link to post Share on other sites
cabrioman 6 Posted May 23, 2011 Report Share Posted May 23, 2011 looks good mate is it going to be a full out and out track car stripped out etc Link to post Share on other sites
bungy 2 Posted May 23, 2011 Report Share Posted May 23, 2011 looks like a lot of car for the money. Link to post Share on other sites
ryanmac 0 Posted May 23, 2011 Author Report Share Posted May 23, 2011 its not going to be full on out and out but I have stripped the interior removing all the soundproofing and anything else that was not required. I have fitted the carpet back in and door cards as I still want it to be a bit comfortable:-) Its going along the lines ofinterior:1 Bucket seat & harnessCarbon fibre door cards but made to original profilerear strut bracesmaller steering wheelfire extingusherkill switchBrakesbraided hoses all roundmk4 rear brakesuprated brake fluidx drilled and grooved discsred stuff padsSuspensionseam welded wishboneswelded up rear beampoly bushed all roundadjustable front top mountsfront upper and lower strut bracesEngine & GearboxMocal oil coolerv5 gearboxlightened flywheelfast road clutchpiper or cat camscone air filterdecat pipe6 branch manifoldsolid front mount vibratechnic mounts elsewhereremapThats the plans anyway and I think it's going to roughly go in that order....hopefully:-) Link to post Share on other sites
matty.vrt 120 Posted May 23, 2011 Report Share Posted May 23, 2011 looks like a minter good luck. Link to post Share on other sites
ryanmac 0 Posted May 29, 2011 Author Report Share Posted May 29, 2011 Cheers for the comments. I am going to keep a bit of a project post going and will update it when I remember. No pics but I will post some up. Interior wise the rear door cards have been done in carbon fibre and I am just waiting for some front door cards to use as a mould. Hopefully they should arrive this week. The wiring is mainly sorted with the kill switch being the only thing left to do along with the replacement of 3 looms which I will get this week. The fire extinguisher is plumbed in and the rear seat area flushed over with a glass fibre sheet and some carpet. The rear strut brace has been welded up and just requires fitting and the battery box for the rear is being made up. I have also relocated the washer bottle to the rear. I am having trouble mounting my bucket seat as I want it as low in the car as possible but I also want to retain the original seat points so I can still use them. On order is a smaller steering wheel with quick release boss.In the engine bay I have tidied up the wiring, relocated the carbon filter, fitted a cone air filter I had lying around and fitted a homemade airbox. I am looking out for a mocal sandwich plate and have one a bmw oil cooler which is on the large side and will require the bumper to be removed for fitting. At some point this month I am going to order the vibratechnic competition mounts, do the diy quick shift mod and fit my homemade front strut brace.Today though I stripped the front and rear brakes off for cleaning and painting while ate the same time pricing up a set of cross drilled and grooved discs with some ebc or pagid rs pads.....think I will leave it the now though as it was coming in at over £350!!!!! for front brakes only. This week I am taking the brake pipes to a company in didcot that make up braided version for about £30 and thats the front and rear. The guy that is selling me the wiring looms also has a fully poly bushed rear axle so I'll pick that up at the same time.So thats it so far Link to post Share on other sites
bungy 2 Posted May 29, 2011 Report Share Posted May 29, 2011 Is there a benefit to seam welding the wishbones? Link to post Share on other sites
ryanmac 0 Posted May 30, 2011 Author Report Share Posted May 30, 2011 on my mk1 and 2 by seam welding them they stiffened them up as they are only really spot welded together. I thought I noticed a difference but then someone else might try it and say it does nothing..... Link to post Share on other sites
bungy 2 Posted May 30, 2011 Report Share Posted May 30, 2011 The only reason I ask is because i've been thinking of putting solid cast TT wishbones on my 4mo and it sparked my interest when I read your idea of seam welding the pressed steel ones. Link to post Share on other sites
ryanmac 0 Posted May 30, 2011 Author Report Share Posted May 30, 2011 Are solid cast ones off a TT not heavy? I still plan on seam welding my ones. It may work this time or it may not but I have a spare set of wishbones lying about. I'll post pics up when I do it.Like I said I noticed a difference in my last 2 golfs but you may do it and not see any difference:-) but it is cheap and only a case of 10 minutes welding. Link to post Share on other sites
bungy 2 Posted May 30, 2011 Report Share Posted May 30, 2011 Been stripping wishbones today and the 4mo ones are seam welded anyway. I can see where there should be benefits though. Link to post Share on other sites
VR6Pete 1,455 Posted May 30, 2011 Report Share Posted May 30, 2011 Lovely raddo there mate Link to post Share on other sites
ryanmac 0 Posted June 2, 2011 Author Report Share Posted June 2, 2011 Cheers pete.Painted the callipers red today but really didn't like them so sprayed them the same colour grey as the car. Link to post Share on other sites
MJ Vr6 79 Posted June 2, 2011 Report Share Posted June 2, 2011 Love the Colour on Raddo!! Looks lovely mate! Link to post Share on other sites
dan_a 1 Posted June 2, 2011 Report Share Posted June 2, 2011 Can't believe you got this for just a couple of hundred! Lovely motor mate. Link to post Share on other sites
leespiro 9 Posted June 2, 2011 Report Share Posted June 2, 2011 hi there nice motor what alloys do u have on you raddo mate Link to post Share on other sites
ryanmac 0 Posted June 2, 2011 Author Report Share Posted June 2, 2011 They are 17" bbs ch painted in la7u pearl grey to match the car and fitted with pirelli p zero nero 40 profile tyres. It had to be 17" to fit over the 312mm brakes. Link to post Share on other sites
Lukey. 381 Posted June 3, 2011 Report Share Posted June 3, 2011 looks like a car that could sell for 10 times what you paid! awesome bargain Link to post Share on other sites
ryanmac 0 Posted June 26, 2011 Author Report Share Posted June 26, 2011 Hi allWell the car starts but it sounds like hell.....It was dry cranked a few times and started. It sounded like there was a stuck tappet. So I gave it a flush with oil and an additive that was recommended but although it has had this done it still sounds rough...anyone fancy some forum diagnostics....here's the vid...http://s844.photobucket.com/albums/ab8/RyanandLindsayMcNeil/all%20things%20corrado/?action=view¤t=DSCF3869.mp4 Link to post Share on other sites
Lukey. 381 Posted June 29, 2011 Report Share Posted June 29, 2011 thought that was what your chains sounded like when they want attention Link to post Share on other sites
VR6Pete 1,455 Posted June 29, 2011 Report Share Posted June 29, 2011 Does the noise come from the left or right side of the engine? (as you face the car) Link to post Share on other sites
ryanmac 0 Posted June 29, 2011 Author Report Share Posted June 29, 2011 the guy had the chains replaced just before he stopped using it and parked it up in his garage. It would have been about 500 miles ago.The noise comes from the left hand side when you face the engine. Link to post Share on other sites
ryanmac 0 Posted June 30, 2011 Author Report Share Posted June 30, 2011 so talking to a couple of guys on another forum and the outcome was I ended up becoming a member of VWDRC.....I don't plan on racing this year due to time and money constraints but I guess it gives me a reason to use the m62 charger I have.... Link to post Share on other sites
