shail 0 Posted February 19, 2005 Report Share Posted February 19, 2005 quickie - wheres the engine number on a coraado VR engine? i cant find it. Been looking for all over. Too cold so ive come back into my house. Ta Link to post Share on other sites
badboyV6 4 Posted February 19, 2005 Report Share Posted February 19, 2005 is it not on the suspension turret or slam panel? Link to post Share on other sites
C8RDO 0 Posted February 20, 2005 Report Share Posted February 20, 2005 Hi there!According to my Corrado instruction manual:The type plate and the vehicle identification number is located on th engine compartment bulk head (The bit at the back/top of the engine compartment when looking from the front)The engine number on the 6 cylinder engine is visible when you look from the drivers side of the engine compartment between the air filter box and the top of the suspension strut. You should see a plate some where on the side of the engine block.There should also be a vehicle data sticker some where in the boot which shows:1 Production control number2 Vehicle identification number3 Model code number4 Model explanation/engine output5 Engine and gearbox code letters6 Paint number/interior trim code7 Optional extra number.Hope this helps a bit. Link to post Share on other sites
shail 0 Posted February 20, 2005 Author Report Share Posted February 20, 2005 Think i must be going blind, cant see anything on the block. new engine so the info on the bulkhead is for old engine. Link to post Share on other sites
trackman 0 Posted February 21, 2005 Report Share Posted February 21, 2005 Just checked on my Golf engine and it's on the offside of the rocker cover on a white (but dirty) sticker with a large barcode and the word 'Motokennbuchsfaben' then the number, in my case AAA ******, but in your case it should be ABV ****** I think.Rich Link to post Share on other sites
shail 0 Posted February 21, 2005 Author Report Share Posted February 21, 2005 Not got that sticker on mine - i know the one you mean. Oh well, guess i'll have to ring up the DVLA to see if they really need the engine number. Link to post Share on other sites
trackman 0 Posted February 21, 2005 Report Share Posted February 21, 2005 Oh, you want it the hard way It's stamped on a flat machined bit on the block at the offside end (pulley end) immediately below where the head meets the block.I'm not sure how easy it is to see in situ as my engine is currently stripped and in the garage.Good luck!!Rich Link to post Share on other sites
