gary_auto 1 Posted May 31, 2011 Report Share Posted May 31, 2011 Is this safe???When i jack the car up the spring comes away. i did take out the helper srping cause they caused more problems.Also when i go over bumper the back makes a noise , found out when i bounce the car up and down the top rear mount moves any reasons why? Link to post Share on other sites
Ian_rogers 0 Posted May 31, 2011 Report Share Posted May 31, 2011 Did u put new mounts on when u fitted them?It's always best to Link to post Share on other sites
gary_auto 1 Posted May 31, 2011 Author Report Share Posted May 31, 2011 Did u put new mounts on when u fitted them?It's always best toThey ware only 2-3months old ?? so no i didnt Link to post Share on other sites
ashmk3 0 Posted May 31, 2011 Report Share Posted May 31, 2011 mine do that i and i have helper springs and no problems or noises here but mine are mk3 vr coilovers on a mk2 golf. Link to post Share on other sites
jims13 6 Posted May 31, 2011 Report Share Posted May 31, 2011 no thats not safe.. helper springs are there for a reason , put it back in along with the plate between the main and helper spring that is missing.dont drive it as it is , its just asking for trouble Link to post Share on other sites
gary_auto 1 Posted May 31, 2011 Author Report Share Posted May 31, 2011 no thats not safe.. helper springs are there for a reason ' date=' put it back in along with the plate between the main and helper spring that is missing.dont drive it as it is , its just asking for trouble[/quote']Quite alot of people do take out the helper spring. i just worried about the top mount on the inside the other side dont do it Link to post Share on other sites
VDub_Steve 1 Posted May 31, 2011 Report Share Posted May 31, 2011 are they fk's i think i have the same when i jack mine up the spring never comes away from the top Link to post Share on other sites
gary_auto 1 Posted May 31, 2011 Author Report Share Posted May 31, 2011 No i think they are joms i just painted the springs yellow. Link to post Share on other sites
VDub_Steve 1 Posted May 31, 2011 Report Share Posted May 31, 2011 oh right well put helper spring back in or you could order a longer spring Link to post Share on other sites
gary_auto 1 Posted May 31, 2011 Author Report Share Posted May 31, 2011 oh right well put helper spring back in or you could order a longer springwith the helper springs tho bit that joins the two springs scrape middle (if that makes sence) Link to post Share on other sites
spadam 7 Posted May 31, 2011 Report Share Posted May 31, 2011 Would definelty put helper spring back if you go over a alrge enough bump and dislocate your spring you will be in big trouble not worth it imo Link to post Share on other sites
gary_auto 1 Posted May 31, 2011 Author Report Share Posted May 31, 2011 I cant understand why so meny people saying putting helper springs back on. i asked on hear few weeks ago and they ware saying its ok to take the helper springs off . bit confused Link to post Share on other sites
VDub_Steve 1 Posted May 31, 2011 Report Share Posted May 31, 2011 oh right well put helper spring back in or you could order a longer springwith the helper springs tho bit that joins the two springs scrape middle (if that makes sence)it shouldnt scrape when they are under load i wouldnt have thought Link to post Share on other sites
gary_auto 1 Posted May 31, 2011 Author Report Share Posted May 31, 2011 oh right well put helper spring back in or you could order a longer springwith the helper springs tho bit that joins the two springs scrape middle (if that makes sence)it shouldnt scrape when they are under load i wouldnt have thoughtIll give it a try , can i put the helper springs on the top? Link to post Share on other sites
VDub_Steve 1 Posted May 31, 2011 Report Share Posted May 31, 2011 oh right well put helper spring back in or you could order a longer springwith the helper springs tho bit that joins the two springs scrape middle (if that makes sence)it shouldnt scrape when they are under load i wouldnt have thoughtIll give it a try ' date=' can i put the helper springs on the top?[/quote']should be ok as long as its snug on the mount and you cant move it Link to post Share on other sites
gary_auto 1 Posted May 31, 2011 Author Report Share Posted May 31, 2011 cheers Link to post Share on other sites
spadam 7 Posted May 31, 2011 Report Share Posted May 31, 2011 Not sure who suggested to remove helper springs but they are there to keep the springs from becoming dislocated. Not sure why they are rubbing though. Do you have any pictures of where it was rubbing. Link to post Share on other sites
gary_auto 1 Posted May 31, 2011 Author Report Share Posted May 31, 2011 Not sure who suggested to remove helper springs but they are there to keep the springs from becoming dislocated. Not sure why they are rubbing though. Do you have any pictures of where it was rubbing.you no the bit that joins the two springs. it rubs on the threded part of the coilover ,witch then makes a nasty noise Link to post Share on other sites
Gazbarber1982 3 Posted May 31, 2011 Report Share Posted May 31, 2011 As a few people have told you already, and there not the dumbest people on here by a long shot, just put it back on! The dampers are set to travel by a set amount; meaning the helper spring is designed to compensate the lowest settings. Removing the spring will shorten the life of your suspension, fail your mot and put yours and other peoples lives in danger. If your really after the lowest suspension n the sh|t ride, then go with what you've got but don't say we didn't warn you!!! Link to post Share on other sites
spadam 7 Posted June 1, 2011 Report Share Posted June 1, 2011 Sounds strange to me were the helper springs at the top or bottom. Link to post Share on other sites
jims13 6 Posted June 1, 2011 Report Share Posted June 1, 2011 the only reason i can see for removing the help spring is to go LOWER than the suspension is designed for .if you do this you void any warrenty, plus other things .if you want to go 120mm lower than stock , then either purchase , said collies for it or get airbags .remember lowering to much will have adverse effects on camber etc. plus the parts of the car that its linked to .your choice, but id put them back as they came pre assembled. Link to post Share on other sites
gary_auto 1 Posted June 1, 2011 Author Report Share Posted June 1, 2011 Cheers guys i will try them again with them on but duno how im going stop the bit that links the two spings from rubbing Link to post Share on other sites
jims13 6 Posted June 1, 2011 Report Share Posted June 1, 2011 it shouldnt if everything is tightend up properly ..is the strut assembled correctly ? with the nuts also tightend correctly ? Link to post Share on other sites
gary_auto 1 Posted June 1, 2011 Author Report Share Posted June 1, 2011 it shouldnt if everything is tightend up properly ..is the strut assembled correctly ? with the nuts also tightend correctly ?I guess so. they ware 2nd hand Link to post Share on other sites
Gazbarber1982 3 Posted June 2, 2011 Report Share Posted June 2, 2011 Rubbing on what? If its rubbing on your tyre the you've either got the camber wrong or the wrong offset wheels Link to post Share on other sites
