b19drg 0 Posted June 12, 2011 Report Share Posted June 12, 2011 as above Drivers elec window inop , passenger side works ok from the switch on drivers door but nothing else , fuses look ok also , ??????? Link to post Share on other sites
b19drg 0 Posted June 12, 2011 Author Report Share Posted June 12, 2011 Anyone ? Link to post Share on other sites
bungy 2 Posted June 12, 2011 Report Share Posted June 12, 2011 I had this problem with my mk3 cabriolet. Worth taking the door card off and checking the connections out. Link to post Share on other sites
Gazbarber1982 3 Posted June 12, 2011 Report Share Posted June 12, 2011 Check the wires in the rubber boot between the door and chassis. My earth wire had split once in the boot Link to post Share on other sites
b19drg 0 Posted June 12, 2011 Author Report Share Posted June 12, 2011 Ah this makes sense now as ages ago I blew the elec window fuse when the door opened , didn't think much about it when it happened , reckon the wire was shorting out Link to post Share on other sites
b19drg 0 Posted June 13, 2011 Author Report Share Posted June 13, 2011 the wires looked all ok in the rubber boot between the door and chassis , have taken my door panels of to and cant see anything obvious ! any other ideas anyone ??? Link to post Share on other sites
bungy 2 Posted June 14, 2011 Report Share Posted June 14, 2011 If you've shorted a connection when opening your door before I would persevere with that Dan as the fault won't just go away. There must be something getting trapped or pulled in there. Link to post Share on other sites
