kentyboy 0 Posted June 22, 2011 Report Share Posted June 22, 2011 right,here goes.recently purchased a 95 vr in storm grey,the handbrake light kept coming on whilst driving,bought vag com,checked it out and it kepy saying rear abs speed sensor problem,found it odd as the abs light didnt come on..later found that somebody had cut the led for the abs and had bent the airbag one to sit between the two holes thus giving it an appearence it was working.well,soldered the led back on and thus,couldnt get the light to go out.vag comed it again and still showed rear abs problem.took rear brakes apart,and no abs rings were fitted,i fitted new ones and sensors,cleared the code down,light went out...took her for a drive,all was ok then the light came back on again,indicating rear right abs problem..cleared the fault code again and same happens again,have done this numerous times,it happens at varying mileages.i even swapped the wires over under the seat to see if it gave the same reading,and it did,rear right abs wheelspeed problem.why does it clear down and run ok for sometimes a short period,sometimes ten or fifteen miles...heeeeeeelp.. Link to post Share on other sites
Gazbarber1982 3 Posted June 22, 2011 Report Share Posted June 22, 2011 Could be a faulty sensor. When I had a similar problem, it was my front abs sensor wire touching on the hot disc. Put it back in the clip and taped it all up and been fine since. Link to post Share on other sites
VR6Pete 1,455 Posted June 22, 2011 Report Share Posted June 22, 2011 Yep probably just a new sensor needed. Easy job to do. Link to post Share on other sites
kentyboy 0 Posted June 23, 2011 Author Report Share Posted June 23, 2011 have changed the sensors and even swapped the wires under the rear seat to see if the fault code changes,but still comes up rear right abs problem...could it poss be the abs controller/ecu unit.. Link to post Share on other sites
ingham 5 Posted July 8, 2011 Report Share Posted July 8, 2011 http://www.clubgti.com/forum/showthread.php?t=224427&highlight=abs+mk3see this about it on cgti Link to post Share on other sites
