Random question time!
Can anyone advise if automotive sandpaper is the same kind of stuff that you can pick up from say Homebase? I need to do my Borbet A rims which will need to be sanded to shine them but other then Halfords - who has a distint lack of options in sandpaper, there isnt anywhere else in my area that sells sandpaper.
Thanks
David
If your doin wheels to a polish you'll want to do it wet so you'll need wet and dry paper which is normally black.
unless it specifies on the pack that it's wet and dry paper i wouldn't use it. normal household sandpaper typically yellowish colour would be no good.
have you got a local motor factor or anything close? halfords is where i got mine from and with a trade card it works out dirt cheap.
Hmmm, i thought that may be the case. The only thing we have is Halfords, which i dont mind using but they only sell it per grade in a pack and at £2 per pack and needing numerous grades it will work out expensive.... i dont have a trade card :-(
I can see what you mean. when i did the lip on my bbs wheels i used 240, 400, 600, 800, 1000, 1200 and 1500. then abrasive polish after that. so a lot of packs needed. i doubt they'd be enough paper in their assorted packs to do all 4 wheels as there's only 1 sheet of each.
how soon do you need then. the other option which might sound silly is ebay? i'm sure there will be loads on there dirt cheap and if you can get all sorts of grit from same company they can post out together.
I can see what you mean. when i did the lip on my bbs wheels i used 240' date=' 400, 600, 800, 1000, 1200 and 1500. then abrasive polish after that. so a lot of packs needed. i doubt they'd be enough paper in their assorted packs to do all 4 wheels as there's only 1 sheet of each.
Think eBay is the only option but kind of wanted it for the weekend as i am dying to put the Borbet's on and i need to polish the lips :-(
Good luck mate, I done a set of these, and they have pitting once you've gone under the lacquer..
Be prepared to go for a Manicure on Monday mornin!! lol
Mind you it depends on what kind of polish your aiming for....!
My mate wanted me to come up with something different, as everyone has there Lips polished, went to plan B,
1
2
3
4
If theres pitting, you need to start from 120, and work your way up dude.
You can use either a Mop at later stages or just sand till P2000, then Autosol them!!!
Bling bling!!
Just use normal Nitromous.
Be careful when using' date=' do not get it on your skin, otherwise your skin will burn like if its on a BBQ.
Pretty simple.
Give us a shout if you get stuck, look out for the pittin!!!!
Sorry for all the questions mate, want to get it right. I have used Nitromors before and it lifts pretty much everything. Would it really be that safe to use as i dont want the paint on the centres to be removed, or would it just be a case of be careful!?
I can just go ahead and do the rears as there isnt laquer, and there is pitting so will have to start with the harsh stuff i guess!
Sorry for all the questions mate' date=' want to get it right. I have used Nitromors before and it lifts pretty much everything. Would it really be that safe to use as i dont want the paint on the centres to be removed, or would it just be a case of be careful!?
Mask the area that you do not require to be touched.
Should be safe enough with Maskin tape..But make sure the surface is clean and the tape stuck down nicely.
Pitting-GOODLUCK! Took me 2 weeks to finish them wheels bud, not an easy task as I do not use a lathe.
All my work done by hand!
Start with P120 on the pitting areas.
Anything else, jus ask or PM.. 8-)
Any further developments on this mate..?
Just replied to you via PM, didnt realise you mentioned the polishing as well. Well i used sandpaper all the way through the scales, made a massive difference and they do have a slight shine to them now but i havent mirror polished them as what i have decided is during the 1st week of august i have a week off of holiday so going to spend a whole week tinkering with the car and wheels.
