All required part numbers for t-stat and crack pipe replacement?
My t-stat housing has started to leak so i need to replace that, but while im in there im gonna renew the whole lot so its a one shot everything done job.
And cos ive read so much that the plastic crack pipes break if you look at them im going to replace it with a metal one, Do C2 still do these?
theres plenty of guides around on how to do it but i can find specific part numbers for what i would need, i understand that this is the list i would need, off the vortex guide for a mk4, is this correct for a mk3 too?
Thermostat Housing
Thermostat Housing Seal
Thermostat
Thermostat Cover
ECU Temp sensor
AC Switch
2 sensor O-Rings
Crack Pipe (a2t2 billet pipe or stock)
Screw-style hose clamps (5 at 2 inch max dia, 1 at 1 inch max dia)
I doubt i would need the sensors, i was just going to re-use mine?
I also heard its a good idea to replace the 2 oil cooler hoses as a matter of course.
any help appreciated
cheers
Found it all out anyway.............
aside form the VW water pipe this is all VW part nos required to fulyy replace the thermostat housing, aswell as the oil cooler hoses while the front ends off
I have used a metal water pipe
thermostat housing - 021121117A
tstat housing gasket - 021121119A
tstat housing cover - 021121121A
tstat housing adapter - 021121133D
adapter O ring - N 10139201
sensor retain clip x3 - 032121142
sensor O ring x3 - N 90316802
thermostat - 075121113D
thermostat O ring - N 90136802
water pipe O ring x2 - N 10139201
oil cooler > water pipe hose - 021121058A
oil cooler > block hose - 021121096
expansion tank - 021121407
2 bottles of G12 plusplus
