when cold the engine sounds like it needs the tappits ajusting , when warm theres no noise at all , does the head gear need replacing ? ie shims or cam rollers , the engine is an early one that vw only used for about 24 months
i would say its timing chains wen engine is cold oil is thick and the tensioner aint getting enough oil but wen its warn oil thins and luricates every thing as it should. ne history? i think thats wat it is?
i just listend to the sound clip on here and mine dont sound like that , the tapping ive got is as though its only on one valve/clyinder ie its not a continuess rattle/tap , she got full vwsh upto 63k then local garage up to 80k
