bells 5 Posted July 14, 2011 Report Share Posted July 14, 2011 when cold the engine sounds like it needs the tappits ajusting , when warm theres no noise at all , does the head gear need replacing ? ie shims or cam rollers , the engine is an early one that vw only used for about 24 months Link to post Share on other sites
b road blaster 0 Posted July 14, 2011 Report Share Posted July 14, 2011 or is it the chains ??? Link to post Share on other sites
bells 5 Posted July 15, 2011 Author Report Share Posted July 15, 2011 or is it the chains ???no its not a chain slap noice it stops as soon as the engine gets any sort of heat into it Link to post Share on other sites
GEPY 0 Posted July 16, 2011 Report Share Posted July 16, 2011 i would say its timing chains wen engine is cold oil is thick and the tensioner aint getting enough oil but wen its warn oil thins and luricates every thing as it should. ne history? i think thats wat it is? Link to post Share on other sites
bells 5 Posted July 17, 2011 Author Report Share Posted July 17, 2011 i would say its timing chains wen engine is cold oil is thick and the tensioner aint getting enough oil but wen its warn oil thins and luricates every thing as it should. ne history? i think thats wat it is?i just listend to the sound clip on here and mine dont sound like that , the tapping ive got is as though its only on one valve/clyinder ie its not a continuess rattle/tap , she got full vwsh upto 63k then local garage up to 80k Link to post Share on other sites
