Vw_owner 1 Posted July 15, 2011 Report Share Posted July 15, 2011 hi guys, just want some advice realy, i have the chance to get a 99 ford galaxy vr6 auto for £150.00 localy, looking on the net etc these engines are VW'S vr6! are they identical ? also is the ford galaxys 24v v6 the same as the mk4's 2.8 4mo motor? im just thinking this galaxy would make a great spare motor and i dont have to travel to get it!! cheers. Link to post Share on other sites
VDub_Steve 1 Posted July 15, 2011 Report Share Posted July 15, 2011 Not sure about the 24v but the vr6 out the galaxy is the same as the golf Link to post Share on other sites
Vw_owner 1 Posted July 15, 2011 Author Report Share Posted July 15, 2011 cheers m8, Link to post Share on other sites
hvr6 88 Posted July 15, 2011 Report Share Posted July 15, 2011 engine same gearbox diffhttp://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?133209.posthttp://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?225894.postfor some part numbers: http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?132303.post Link to post Share on other sites
Dave_ciw 507 Posted July 15, 2011 Report Share Posted July 15, 2011 To be fair I have had people come to me for engines from a golf to fit their Sharan or Galaxy and I have offered to take their engine in exchange! But side by side they are different..... The cylinder head has more coolant hoses and connections on the people carriers than the golf! Link to post Share on other sites
russj249 2 Posted July 15, 2011 Report Share Posted July 15, 2011 Don't the people carriers have an air port for something on the front of the head too? i've heard it'd need to be plugged by welding something in if put into a golf. Link to post Share on other sites
Antihero1981 8 Posted July 16, 2011 Report Share Posted July 16, 2011 are the cams different? Link to post Share on other sites
Vw_owner 1 Posted July 16, 2011 Author Report Share Posted July 16, 2011 ok scrap the galaxy, an hour later a mk3 golf vr6 came my way for £200! the guy had it advertised as possible clutch problem as it didnt drive,my m8 towed me to my works carpark ,i had a proper looksy and found that the driveshaft had comeloose and as a result he had bent and sheered the bolts off the flange,not a problem for me as i have a brand new bolt set which i didnt use on the corrado! fitted the driveshaft back with new bolts about 2 hours ago, just need to replace the fuel hoses in the bay as there perished and spraying petrol everywhere! he must of been useing it like that! think iv got myself a little bargain! realy needs an oil change and the oil cooler seals doing which i'll do on thursday,right can someone shed some light on this, this model has a coilpack does this make it obd2? cheers Link to post Share on other sites
v6horse 1 Posted July 16, 2011 Report Share Posted July 16, 2011 Both obd1 and obd2 had the coilpack , only way to tell if I'm not mistaken is the check the throttle body . There is a sticky somewhere thart shows the difference . Link to post Share on other sites
Vw_owner 1 Posted July 16, 2011 Author Report Share Posted July 16, 2011 ah cheers, didnt realy take a good look at the TB but it all looked prety much the same as my corrado so that makes it obd1! Link to post Share on other sites
rsweeney 40 Posted July 17, 2011 Report Share Posted July 17, 2011 ok scrap the galaxy' date=' an hour later a mk3 golf vr6 came my way for £200! the guy had it advertised as possible clutch problem as it didnt drive,my m8 towed me to my works carpark ,i had a proper looksy and found that the driveshaft had comeloose and as a result he had bent and sheered the bolts off the flange,not a problem for me as i have a brand new bolt set which i didnt use on the corrado! fitted the driveshaft back with new bolts about 2 hours ago, just need to replace the fuel hoses in the bay as there perished and spraying petrol everywhere! he must of been useing it like that! [img']http://i1206.photobucket.com/albums/bb441/chris2fer666/mk3backrightshot.jpgthink iv got myself a little bargain! realy needs an oil change and the oil cooler seals doing which i'll do on thursday,right can someone shed some light on this, this model has a coilpack does this make it obd2? cheersthat is so lucky , proves that it is worth taking a look at things first before writing them off. quite jeaulous now! Link to post Share on other sites
Vw_owner 1 Posted July 17, 2011 Author Report Share Posted July 17, 2011 haha yea saw it on facebook guernsey classifieds,i was in there like swim wear just finished off the fuel lines so its now driveable, needs 2 new tyres, oil cooler seals and an oil change, at the mo the oil level is dangerously low,and the rear disc pads need doing and the exhaust is getting changed as its so so quiet you can barely hear it, doesnt even sound like a vr6 imo.might just sort out the problems and give it a good clean and put it up for £1000 o.n.o as i dont realy need another car but i could hardly turn down a vr6 for £200 Link to post Share on other sites
