Peakz 0 Posted February 24, 2005 Report Share Posted February 24, 2005 Hi chaps, I'm new to this site but a veteran VW fanatic.I've just bought a gorgeous Vento VR6 and want to get an uprated headlamp loom to beef up the weak lighting.Where can I get one fitted and how much are they?Can I get one s/h and if so how much are they worth?? Link to post Share on other sites
badboyV6 4 Posted February 24, 2005 Report Share Posted February 24, 2005 You could get HID gas discharge lamp conversion. I think there was a few people talking of a group buy. I cant remember the price around 2-300 quid i think..... :-) apparently they are pretty easy to fit. Link to post Share on other sites
Peakz 0 Posted February 24, 2005 Author Report Share Posted February 24, 2005 I wasn't thinking of spending quite so much, I planned on spending upto £100 max.Pretty car you have there badboy! Link to post Share on other sites
badboyV6 4 Posted February 24, 2005 Report Share Posted February 24, 2005 hmmm i found the mk4 style lights slightly better but not a 100 quid better- more for looks. Not sure what beefing up the loom itself will achieve.... Maybe someone else will be able to help... BTW you should post some pictures of your Vento in the members car section... And thanks for the comments :-) Link to post Share on other sites
mightyvr6 0 Posted February 25, 2005 Report Share Posted February 25, 2005 An uprated headlight loom costs about £30 Link to post Share on other sites
Peakz 0 Posted February 25, 2005 Author Report Share Posted February 25, 2005 Hi mighty, where can I get one from at that price? Link to post Share on other sites
mightyvr6 0 Posted February 25, 2005 Report Share Posted February 25, 2005 Peakz, you have pm. Link to post Share on other sites
dubloke 4 Posted February 26, 2005 Report Share Posted February 26, 2005 can i have pm too mighty?badboy-beefing up the loom equates to alowing you to run higher powered bulbs in the lights without melting the existing wiring or constantly blowing fuses! Link to post Share on other sites
Peakz 0 Posted February 26, 2005 Author Report Share Posted February 26, 2005 Thanks for your help mighty but I've managed to get an uprated loom out of another Vento.The standard loom loses at least 2V through resistance which means your bulbs have less power going into them hence the poor light output.The uprated loom uses a more direct feed from the battery allied to relays. The end result is a full 12v volts going into your bulbs giving you full wattage.Of course the other advantage to using this is that you can use off-road bulbs of a higher rating without frying everything in its path![ Edited Sat Feb 26 2005, 07:49PM ] Link to post Share on other sites
badboyV6 4 Posted February 26, 2005 Report Share Posted February 26, 2005 Ah i see... :-) Is it much of a pain fitting the uprated loom then? Link to post Share on other sites
Peakz 0 Posted February 26, 2005 Author Report Share Posted February 26, 2005 Er, I'll let you know when my friend and I fit it.By all accounts it looks relatively straight forward, so much easier with the kit coming from an identical Vento too! Link to post Share on other sites
robvr6 0 Posted April 5, 2006 Report Share Posted April 5, 2006 does anyone know where to buy the uprated looms from? Link to post Share on other sites
