DsH 2 Posted July 24, 2011 Report Share Posted July 24, 2011 i think my battery has died and my car has no key holes just my clifford security alarm, so i cant get to the bonnet to jump it or anything, what can i do!!! Link to post Share on other sites
DsH 2 Posted July 24, 2011 Author Report Share Posted July 24, 2011 bump, sorry this is really urgent! Link to post Share on other sites
Daverse 175 Posted July 24, 2011 Report Share Posted July 24, 2011 depending on how old the bonnet latch is, you might be able to get your hands under the bonnet and give it a sharp tug upward and that will undo the latch. or try to get a screw driver around the locking mechanism. hope that helps Link to post Share on other sites
DsH 2 Posted July 24, 2011 Author Report Share Posted July 24, 2011 its a '93 i'll give that a go, thanks Link to post Share on other sites
VR6Pete 1,455 Posted July 24, 2011 Report Share Posted July 24, 2011 This is why you should have a lock somewhere on the car been here, done that Link to post Share on other sites
DsH 2 Posted July 24, 2011 Author Report Share Posted July 24, 2011 no time for gloating, i bought the car like this, i need it sorted before dinner time. Link to post Share on other sites
VDub_Steve 1 Posted July 24, 2011 Report Share Posted July 24, 2011 If you can get grill of there is a bit of plastic on the radiator panel covering the bonnet latch I had to cut a little bit out to reach the cable then voila Link to post Share on other sites
DsH 2 Posted July 24, 2011 Author Report Share Posted July 24, 2011 i can get the grill off, infact ive got the grill off, it was easy because its debadged, are you referring to the big plastic strip ontop of where the radiator is i can touch the release with my index finger, where abouts did u cut off? Link to post Share on other sites
VDub_Steve 1 Posted July 24, 2011 Report Share Posted July 24, 2011 Can you pm me ur number probably easier to explain over phone Link to post Share on other sites
DsH 2 Posted July 24, 2011 Author Report Share Posted July 24, 2011 pm'd Link to post Share on other sites
Ian_rogers 0 Posted July 24, 2011 Report Share Posted July 24, 2011 If uve got the grill off u can undo the bolts that secure the whole mechanism to the car, it's fiddely but doable I had to do the same Link to post Share on other sites
DsH 2 Posted July 24, 2011 Author Report Share Posted July 24, 2011 ok thanks ive seen the two bolts are they the only two i need to undo because they're the only ones i can see/ get too Link to post Share on other sites
L55KE B 1 Posted July 24, 2011 Report Share Posted July 24, 2011 Have u got into the car yet? I've also got no locks on my car so when my battery goes flat this is what I doJack up the front of the car. Carefully Attach the red jump lead to the power cable connection for the starter motor (but make sure it does not touch any part of the engine) Then attach the black jump lead to a good clean part of the engine or gearbox.Hook up the other end of the jump leads to a battery or car and you should should now have power so you can operate your remote central locking and get into the car!Hope this helps Link to post Share on other sites
DsH 2 Posted July 24, 2011 Author Report Share Posted July 24, 2011 i'll have to give this a go, how high off the ground do i have to lift the car? Link to post Share on other sites
DsH 2 Posted July 24, 2011 Author Report Share Posted July 24, 2011 still not running and its too low to jack upm where would be the best place to jack the car up given if i use 2 small jacks to raise it a little then stick my big jack underneath? there doesnt seem to be any decent mounting points. Link to post Share on other sites
VDub_Steve 1 Posted July 24, 2011 Report Share Posted July 24, 2011 If you got a big jack then just take ur splitter off and jack it up on front cross member Link to post Share on other sites
bungy 2 Posted July 24, 2011 Report Share Posted July 24, 2011 Very easy if it is just a flat battery. remove an indicator and connect a 12v battery there to the terminals. It will be enough to operate the central locking and no damage. Link to post Share on other sites
Ian_rogers 0 Posted July 24, 2011 Report Share Posted July 24, 2011 Yeah that's the only bolts u need to undo mate n the whole mechanism will lift up Link to post Share on other sites
ian_GTI 0 Posted July 24, 2011 Report Share Posted July 24, 2011 Very easy if it is just a flat battery. remove an indicator and connect a 12v battery there to the terminals. It will be enough to operate the central locking and no damage.This is by far the easiest thing to doAll it does is reverse feeds the ignition Link to post Share on other sites
Lukey. 381 Posted July 25, 2011 Report Share Posted July 25, 2011 does it not have a boot key lock? Link to post Share on other sites
DsH 2 Posted July 26, 2011 Author Report Share Posted July 26, 2011 the bonnet release snapped aswel so now we're going to unbolt the actual locking mech and then we should be alright, we've got a new cable how hard are these to fit? but yeah we finally broke in with the good old wired clothes hanger but the cables snapped so thats no good Link to post Share on other sites
Ian_rogers 0 Posted July 26, 2011 Report Share Posted July 26, 2011 It's probably not broke, there is a section half way down the wing that separates so it's more than likely that Link to post Share on other sites
DsH 2 Posted July 26, 2011 Author Report Share Posted July 26, 2011 nah i cut the cables cover and actually pulled the cable through its definitely snapped Link to post Share on other sites
Ian_rogers 0 Posted July 26, 2011 Report Share Posted July 26, 2011 Ah I see! Good luck with it Link to post Share on other sites
DsH 2 Posted July 26, 2011 Author Report Share Posted July 26, 2011 hey guys got the bonnet up, hooked it up to my other car, gave it 5 minutes and nothing, absolutely nothing happened, no lights on the dash came up no interior lights came on, its been 10 minutes no and still, nothing, what could this be? Link to post Share on other sites
