as long as you have 288m fronts, but the rears are no good though as they are different, they are a different size, offset and the wheel bearing is integrated into the VR6 ones.
as far as rear discs you need ones specifically for the VR6 so they wont be very cheap.
I stress, you need 288mm front brakes for them to work.
I used Golf mk4 TDI 150 front discs and pads on my VR6 and they fit them same though.
