DsH 2 Posted August 6, 2011 Report Share Posted August 6, 2011 http://www.ebay.co.uk/itm/GOLF-MK4-TDI-FRONT-REAR-BRAKE-DISCS-PADS-97-04-150bhp-/110701020285?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19c64b847d#ht_1837wt_905a mk3 vr6, brakes on it atm are standard, someone said mk4 golfs brakes are identical, can someone else confirm this? Link to post Share on other sites
russj249 2 Posted August 6, 2011 Report Share Posted August 6, 2011 those are 288mm like on the OBD2 VR's yes. The early ones don't fit as they are 280mm.However the rears on the VR6 have the bearing pressed into them, where as the mk4's are seperate. You may need to look into this. Link to post Share on other sites
DsH 2 Posted August 6, 2011 Author Report Share Posted August 6, 2011 my vr is 1993 which is under obd1 but i actually have an obd2 port so im not sure what previous owners have done, i'll haveta measure them i guess Link to post Share on other sites
Gazbarber1982 3 Posted August 6, 2011 Report Share Posted August 6, 2011 It's a standard port, even on yours. They changed to it on a K plate. If yours is 93, they will be 280mm Link to post Share on other sites
