*P3nfold* 0 Posted August 17, 2011 Report Share Posted August 17, 2011 Where is the best place to wire the power for the gauges? Link to post Share on other sites
craggsy 91 Posted August 17, 2011 Report Share Posted August 17, 2011 I think I wired a cable from battery and ran em off that. Obviously with a fuse near battery. Ran it thru a grommet underneath coolant bottle with the boost hose for that gauge.Buy I wasn't to fussed on looks tho Link to post Share on other sites
Lukey. 381 Posted August 17, 2011 Report Share Posted August 17, 2011 They aren't high power or anything you could just run them off an ignition live already in the dash Link to post Share on other sites
GordonC 20 Posted August 17, 2011 Report Share Posted August 17, 2011 Could you not wire them from the constant 12v for the stereo ? Would be a lot easier than running another wire all the way from the battery mate Link to post Share on other sites
*P3nfold* 0 Posted August 17, 2011 Author Report Share Posted August 17, 2011 They aren't high power or anything you could just run them off an ignition live already in the dashWould this mean the dials would only work once the key is in the ignition? Link to post Share on other sites
spadam 7 Posted August 17, 2011 Report Share Posted August 17, 2011 Yea would only come on when ignition is on which is what you would want. Should be a few wires you could you under there. Link to post Share on other sites
*P3nfold* 0 Posted August 17, 2011 Author Report Share Posted August 17, 2011 Thanks Adam, I will get on this tonight after the mass checks I need to go through. Link to post Share on other sites
Timah89 1 Posted August 17, 2011 Report Share Posted August 17, 2011 i wired mine from the cigarette lighter, just ran a split from it Link to post Share on other sites
MJ Vr6 79 Posted August 17, 2011 Report Share Posted August 17, 2011 I used power and earth from the rear demister switch, as I found this the best alternative rather than Fuse box.Currently running Psi gauge, Battery, Oil Pressure. Link to post Share on other sites
nedvrt 25 Posted August 17, 2011 Report Share Posted August 17, 2011 im running boost wide band and oil temp and pressure and water all into three chock blocks. 1 to power 1 to ground on dash and the ignition off the yellow and black wire commin out the ignition barrel Link to post Share on other sites
Lukey. 381 Posted August 17, 2011 Report Share Posted August 17, 2011 I run mine off the radio ignition live, yea it means that they would only run when the ignition is turned on, no point in them being permanent live they'll just run your power down Link to post Share on other sites
*P3nfold* 0 Posted August 18, 2011 Author Report Share Posted August 18, 2011 Wired in I used the radio ignition. Thanks guys. Link to post Share on other sites
