leespiro 9 Posted August 19, 2011 Report Share Posted August 19, 2011 hi guys looking to supercharge my vr in the next month or so does any one have a kit for sale or where is the best place to get on from Link to post Share on other sites
rodney 17 Posted August 19, 2011 Report Share Posted August 19, 2011 always worth a browse in the for sale section.. other wise other than VF direst... NSracing/Regal/sparkz are the ususal suspects Link to post Share on other sites
rodney 17 Posted August 19, 2011 Report Share Posted August 19, 2011 ps someones breaking one on here... Link to post Share on other sites
*P3nfold* 0 Posted August 19, 2011 Report Share Posted August 19, 2011 I would ask nstuning, I bought my kit from them, bloody good guys.. Highly recommended. Link to post Share on other sites
ANDREW 30 0 Posted August 20, 2011 Report Share Posted August 20, 2011 I've got a full new rotrex kit that i've never got round to fitting, plus i've got a load of other performance bits list below!All are new and mean't to be fitted to my VR6 corrado.280mm rears brake kit, stainless 6 branch manifold heat wrapped , 63mm stainless decat, sp263 cams, lightened flywheel, ARP head studs & conrod bolts, 360cc redtop injectors, rotrex C30-84 kit, water/meth injection &alloy tank, headspacer, full set vibratechnics mounts, black samco hose set Link to post Share on other sites
leespiro 9 Posted August 20, 2011 Author Report Share Posted August 20, 2011 hi how much for the rotrex kit Link to post Share on other sites
ANDREW 30 0 Posted August 20, 2011 Report Share Posted August 20, 2011 Depending on exactly what you want included, but for Rotrex supercharger plus manual, 6 psi Rotrex pulley, standalone Rotrex oil kit, bracket and bearings set, supercharger belt, rising rate fuel pressure regulator, intake pipework and filter, silicon pipes and fittings, new vw tensioner, air-conditioning bypass bracket and idler and a set of redtop injectors (recon) i'm sure there are a few odds and ends i've forgotten but i want £2350 this it's all new, a few brackets were test mounted but thats it! When i said depending on how much you want i've also got a new headspacer and a water meth injection system, plus a 6 branch manifold and a decat. All this takes my kit to the equivalent of the storm stage 1 kit which from them costs £3675 +VATI've also got the ARP rod and head studs too!! Link to post Share on other sites
Antihero1981 8 Posted August 20, 2011 Report Share Posted August 20, 2011 check out edition38 , someone selling a vf9 on there Link to post Share on other sites
*P3nfold* 0 Posted August 20, 2011 Report Share Posted August 20, 2011 Hey lee, I must admit the Rotrex is an awesome bit of kit and is not like any other charger in terms of efficiency and power delivery.Craggys ran one on this VR for a year or so I believe but hes engine went pop due to age.I am currently running a Vortech V3 though will some running issue. The car is currently on positive boost at around 2500rpm under throttle so its good for the mid range torque backed up with a set of Schimmel 263 cams.So for me its ideal and it really depends on how fierce you what the power delivery from the charger? I read and heard the rotrex give's you positive boost from engine on but cannot validate that. Link to post Share on other sites
harris2182 0 Posted August 22, 2011 Report Share Posted August 22, 2011 would this rotex kit be good for mk3 golf of all variants. (if any) im currently hunting down a gold and want to charge it. this kit sounds awesome Link to post Share on other sites
