Mastiff 0 Posted August 26, 2011 Report Share Posted August 26, 2011 My VR has a Magnex s/s exhaust which has a de-cat.....Would having a de-cat improve performance?Also I have a direct feed to my airbox from the front fog but if I was to drill a few holes in it like Nat has on here would it benefit any more as in performance?My direct feed mod'.....Meant me loosing the front fog light but easy enough to put back in and I have MK4 lights with upgraded bulbs so lighting is not an issue! Link to post Share on other sites
legvw 0 Posted August 27, 2011 Report Share Posted August 27, 2011 Drilling your air box, from experience, only creates induction noise, and defeates the object of your cold air feed by drawing hot air from your engine bay.You might gain a couple of bhp from the de-cat and exhaust, maybe gain a little mid-range torque. Link to post Share on other sites
Mastiff 0 Posted August 27, 2011 Author Report Share Posted August 27, 2011 Drilling your air box' date=' from experience, only creates induction noise, and defeates the object of your cold air feed by drawing hot air from your engine bay.You might gain a couple of bhp from the de-cat and exhaust, maybe gain a little mid-range torque.[/quote']Thanks bud......I wont be drilling my airbox then!So a few extra ponies may have been gained due to the exhaust. I must get her RR'd and see what she is producing. Link to post Share on other sites
editionmatt 1 Posted August 27, 2011 Report Share Posted August 27, 2011 i dont think youl see many gains until you started changing engine parts, once you have done the exhaust and induction then the only way of seeing noticeable power increase is by doing cams and or upgraded inlet manifold along swith a map to suit. very expensive shizney! obv age is a big factor that can effect your figures so its also worth giving her a good service and ironing out any creases Link to post Share on other sites
gavster_vr 0 Posted August 28, 2011 Report Share Posted August 28, 2011 Like the idea of the fog light as a cold air feed hole..like the others said too m8 drilling holes the air box will intake warm air from around ya engine :-0 Link to post Share on other sites
jims13 6 Posted August 28, 2011 Report Share Posted August 28, 2011 you need one of my pipercross panel filters Link to post Share on other sites
Mastiff 0 Posted August 28, 2011 Author Report Share Posted August 28, 2011 you need one of my pipercross panel filters How much are they bud......Do panel filters really make a difference? Link to post Share on other sites
jims13 6 Posted August 28, 2011 Report Share Posted August 28, 2011 well, a standard filter flows well. cone filters sound nice , but suffer from heat soakso a panel filter is the best of both worlds, as it uses the standard air box , but with a better filter design .. and you get some noise filters are £38 pounds to your door Link to post Share on other sites
