v6horse 1 Posted August 27, 2011 Report Share Posted August 27, 2011 Hey guys . I should hopefully be getting a charger however the one Im getting comes with the belt that is for a non-ac car , Does anyone know what belt to use with an ac engine ?cheers in advance PS: did a search and didnt find anything so if there is a page im sorry for posting . Link to post Share on other sites
Antihero1981 8 Posted August 28, 2011 Report Share Posted August 28, 2011 should be nearly the same size as the tensioner would be in the same place as aircon , you could always test fit and see , i just loosed my vf9 and adjusted the outlet to suit the throttle.... Link to post Share on other sites
v6horse 1 Posted August 29, 2011 Author Report Share Posted August 29, 2011 Are you sure i could use my oem ac belt as I will have just 1 day to fit the charger at my work and then the car need to be off the ramp , Also wondering , what size compression gasket will i need to use to get my compression down to 8.5:1 , is it 1.5 mm or 2 mm ? cheers guys Link to post Share on other sites
Antihero1981 8 Posted August 29, 2011 Report Share Posted August 29, 2011 mmmm not sure on compression but someone will sort you out with that answer.i used a normal aircon double sided belt , just had to tension less , but thats on a vf9 Link to post Share on other sites
